| naro914 |
Dec 3 2013, 05:41 PM
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Not sure if this should go here, but figured it would be the least offensive to the moderators...
We've developed a weld-in 914-6 mount that's similar in design to the Patrick Motorsports mount, but has some improvements with strengthening and angles. I personally run these on both of our cars: Huey with a stock 3.2 liter Papa Smurf with a full out 350 hp, 275 lb/ft torque, twin plugged 3.2 liter No problems, no issues, easily handles the power and makes installing the engine actually really easy! Price is $375 plus shipping (usually about $25) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| JmuRiz |
Dec 3 2013, 07:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Great looking mount, I would recommend (the only reason I went RJ mount was a killer deal). In hindsight, I would buy naro's anyway.
| carr914 |
Dec 3 2013, 08:15 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,990 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Bob, what are the Bushings made of? You should think about Delrin
| naro914 |
Dec 3 2013, 10:20 PM
Delrin... (IMG:style_emoticons/default/smile.gif)
Actually what you don't see (and I should have taken pictures of) is that the bushing slots into the tube on the mount pretty far on either side. they just about touch in the middle. Need a picture to explain better... Will get one. |
| billh1963 |
Dec 7 2013, 06:44 AM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Bob,
I'll be needing a mount for my conversion on the green car. This looks like a nice unit. Can you tell me more about why this mount is better than other units offered including the Porsche design? Thanks, Bill |
| carr914 |
Dec 7 2013, 08:48 AM
Bob, I'll be needing a mount for my conversion on the green car. This looks like a nice unit. Can you tell me more about why this mount is better than other units offered including the Porsche design? Thanks, Bill Bill, I can answer a few things for you and Bob can tell you why it's better that Patrick's Porsche's is a single mounting point with one Bolt. It's fine for a Real -6 with a 2.0, but if you get some bigger HP, (IMG:style_emoticons/default/confused24.gif) Rich Johnson's that has been copied by MadDog is a fixed 2 Point Mount that can be Blted in or Welded Patrick's like Naro's is a 2 Point Mount, but it's hinged, so you can bring the Motor down to do Valve Adjustments. Bob will tell you the improvements he has made. |
| naro914 |
Dec 7 2013, 10:53 AM
Regarding the improvements, we found the Patrick mount needed more support at a few points - both on the weld-to-the-chassis mounts and the engine cradle. We actually used a program from Gibbs Racing - which measures strength and weakness points - to design it.
For example: look at the Patrick pieces that weld (or bolt) to the chassis. See how the connection for the engine cradle is at the END of the mount? On ours, we 'cradle' it, and make the mount a bit bigger and stronger - to add more support. there are also additional supports on the engine cradle too, just hard to see from the Patrick pictures... ![]() ![]() Don't get me wrong, Patrick's mounts are good mounts, we just think we were able to improve on them some and offer them at a lower price. |
| naro914 |
Dec 10 2013, 07:55 AM
A couple people have asked about a template for the mount. I will include simple instructions and this diagram, but I thought I would post it here too:
Mounting location is very easy: assemble the mount (bolt the pieces together with all bushings in place) and fit the welding plates into the corner created by the ridges in the firewall sheet metal and the bottom ridge/lip. Mark the location of the weld plates, then disassemble and weld on your plates individually. I would recommend re-checking your location after you're first plate is welded in case you move it a little - just reassemble and make sure your second mount is still aligned. ![]() We tried to design this to make installation as easy as possible. One thing that every mechanic that's worked on the car since it's been installed says is that putting the engine in and out is now REALLY easy - you just raise the engine to the point that the cross member slides in between the chassis mounts and run the bolts through. The engine can be at an angle and still be bolted in, allowing you to then focus on the transmission mounts. |
| naro914 |
Dec 17 2013, 07:13 AM
One left in stock to be shipped in time for Christmas!
More being made over the next few weeks. |
| -JR- |
Jan 9 2014, 12:04 AM
Life goes faster at 150MPH ![]() ![]() Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
Any idea if these are compatible with a stock 3.6?
One picture you have showing the front pulley looks very close to the engine mounting frame. But I can't see the offset depth (2D photo) so I'm not sure. Need a mount for my 3.6 street project car. Also, I'm a little concerned about engine vibration with these bushings. Can you provide any feedback on that? Are you familiar with a polyurethane equivalent I could sub? Thanks! |
| naro914 |
Jan 9 2014, 10:22 AM
JR
I don't see a problem with using the mount for a stock 3.6 liter, but I will be honest and say that we have not done that yet. Dimensionally, it is the same at the Patrick mount that they do use for 3.6 installs, so I would think it would be fine. You do get some engine vibration felt through the car as yes, the bushings are fairly stiff. The problem with using softer bushings is that the through bolt is basically resting on the bushing, so if it was soft and pliable, it would compress and allow the entire mount to 'sag'...if that makes any sense? |
| -JR- |
Jan 10 2014, 01:54 AM
Super thanks!
Not quite ready to move ahead yet with the mount as I haven't started the project yet. But I'm very interested in this mount when I'm ready. Probably talk to you again in another two-three months for one. Thanks again. JR I don't see a problem with using the mount for a stock 3.6 liter, but I will be honest and say that we have not done that yet. Dimensionally, it is the same at the Patrick mount that they do use for 3.6 installs, so I would think it would be fine. You do get some engine vibration felt through the car as yes, the bushings are fairly stiff. The problem with using softer bushings is that the through bolt is basically resting on the bushing, so if it was soft and pliable, it would compress and allow the entire mount to 'sag'...if that makes any sense? |
| naro914 |
May 12 2014, 08:33 AM
One currently in stock!
| spsader |
Jul 12 2014, 04:54 PM
Newbie ![]() Group: Members Posts: 49 Joined: 22-January 13 From: Montreal, Qc Member No.: 15,409 Region Association: Canada |
Just recently picked up an '89 3.2 and will be needing a mount, yours looks good do you still have one available?
Thanks Paul |
| naro914 |
Jul 13 2014, 04:26 AM
Hi Paul
Yes, I do have one available. |
| spsader |
Jul 13 2014, 10:12 AM
PM sent
Paul |
| mmascari |
Dec 22 2014, 01:26 PM
Member ![]() ![]() Group: Members Posts: 322 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Hi I am interested in purchasing one of these mounts if you are still producing them. I sent you a PM.
| naro914 |
Jan 10 2015, 07:33 AM
Very frustrating....I apologize to anyone that was waiting on one. They are back into production as of 11/8/15!! |
| no1uno |
Jan 12 2015, 02:45 PM
Member ![]() ![]() Group: Members Posts: 206 Joined: 2-December 10 From: Melbourne, FL Member No.: 12,448 Region Association: South East States |
Keep us posted. I would also be interested when they go back into production
| naro914 |
Nov 8 2015, 08:58 PM
UPDATE:
We FINALLY have them back into production!! I have one in stock right now, and will have a bunch stocked up right after Thanksgiving. Get your order in now for your -6 conversion winter project!! |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:00 PM |
