Intermittent Idiot Light, Impending doom? |
boxsterfan |
Dec 9 2013, 11:44 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
My oil pressure idiot light came on the other day on the way to the 914 meeting at Alice's restaurant. Happened a 3-4 times as we were going through the twisties and would always turn back off.
Today, it happened again but this time driving around San Ramon. However, it came on this time when making a left while driving through a parking lot at about 15-20 miles per hour. And it of course did turn back off just as it had during the drive to Alice's restaurant. I would estimate it is never on for more than 3-5 seconds. Impending doom? I'm too wiped out tonight, but will double check that I am filled up on oil as my 2.0L does have some leaks. If my wallet had less leaks so would my 2.0L. (IMG:style_emoticons/default/rolleyes.gif) |
Rand |
Dec 10 2013, 12:14 AM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
My oil pressure idiot light came on the other day on the way to the 914 meeting at Alice's restaurant. Happened a 3-4 times as we were going through the twisties and would always turn back off. Today, it happened again but this time driving around San Ramon. However, it came on this time when making a left while driving through a parking lot at about 15-20 miles per hour. And it of course did turn back off just as it had during the drive to Alice's restaurant. I would estimate it is never on for more than 3-5 seconds. Impending doom? I'm too wiped out tonight, but will double check that I am filled up on oil as my 2.0L does have some leaks. If my wallet had less leaks so would my 2.0L. (IMG:style_emoticons/default/rolleyes.gif) I just put a flashing light on my forehead, so everyone knows I am intermittent. Idiot is inferred. (IMG:style_emoticons/default/laugh.gif) I would think you would check your oil levels before asking about impending doom in front of the world? (IMG:style_emoticons/default/wink.gif) Oh, sorry, you are too wiped to pull the dipstick? But you can find the energy to post here? (IMG:style_emoticons/default/confused24.gif) Just givin you crap. (IMG:style_emoticons/default/beerchug.gif) But.... What was the oil level? |
Jeffs9146 |
Dec 10 2013, 12:22 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
A leaking or bad oil pressure sensor, low oil level and a grounding sensor wire could cause these symptoms! Check them all before you worry about the motor! My 2.0L would flash the light when hard cornering but not in a parking lot!
boxsterfan |
Dec 10 2013, 05:20 PM
Turns out the oil was low. It was just too fickin' cold to head back out to the garage last night to check it.
Anyway, the dipstick showed the oil coming to the point halfway between the bottom fill line and the end of the dipstick. Down about 1 quart I guess. I poured in another quart this morning. Regarding oil consumption: 1. My car has some oil leaks. Just ask the cardboard box I put under it in the garage. 2. Preferrably, it is little to none, but what are acceptable rates of oil consumption on a 2.0L Type IV? I'm guessing my car went through about 1 quart in 1,500 miles. |
IronHillRestorations |
Dec 12 2013, 07:56 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
IIRC the recommended max oil consumption is a quart every 600 miles, which is a lot of oil. When in doubt change the oil & filter and cut the filter open. If you see any metal, you've got trouble.
rhodyguy |
Dec 13 2013, 06:49 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
figure out where the leaks are coming from. seepage from the valve covers is prob a result of your valve adjustment.
boxsterfan |
Dec 13 2013, 10:50 PM
figure out where the leaks are coming from. seepage from the valve covers is prob a result of your valve adjustment. It's not leaking there from what I can tell. Anyway, 1QT oil in 1500 miles is not great but that also does not make it priority #1 to work on yet. See my brakes thread for my next project. |
mrholland2 |
Dec 14 2013, 12:18 AM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Any oil leak does NOT count in the 1 quart per 600 miles (or so) max oil consumption standard. It sounds like the leak could be a substantial portion of that.
Lo-Fi Version | Time is now: 29th May 2024 - 04:25 AM |
