brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,011 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Sorry, I just needed to run this by someone.
I'm looking at buying a used flywheel that was run on a 71.. 6bolt.. 911 motor seller said he ran it with a 225mm clutch application. Am I correct in remembering that a stock 914 clutch is actually 215mm? Is the 225mm application the one where you invert the tranny to a pull clutch? just want to make sure I don't buy something that won't fit... thanks all brant |
brant |
Bump...
ok so I've verified that a stock clutch is 215mm. So someone chime in... is the 225mm set up the one that is used on the 71 911 with the other clutch? sounds like I don't want this flywheel unless I intend to switch the pressure plate too....... brant |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
225 MM is a pull type clutch. To use it with a 901, you have to have the correct shift fork, throwout bearing, and clutch disk from a 70-71 911. You have to move the pivot point 14mm outboard, and use the reinforced pivot pin, not the stock one.
The upside is you get rid of the clutch pulley. |
brant |
Clay,
thanks for your time.. I kinda thought this was the wrong one, but appreciate the verification. brant |
Lo-Fi Version | Time is now: 11th July 2025 - 08:39 AM |
