FPR/Dual Carbs/FPG? |
ETMracing |
Dec 11 2013, 11:43 AM
Newbie Group: Members Posts: 37 Joined: 22-August 13 From: frederick md Member No.: 16,288 Region Association: MidAtlantic Region |
Been reading quite a bit of posts from here that date back to 05' and have some great input.
Re-doing my dual carb fuel line routing on my 914/4 2.0. Tank, pre filter, low pressure pump,.....then should it go fpr, gauge, t-fitting, carbs, no return? Its a 1 in 2 out FPR. And a inline FPG. Thanks 914World |
brant |
Dec 11 2013, 11:55 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
there are benefits of a return line
thats how the factory did it and it does keep the fuel cooler and thus adds power here is a thread with diagrams its been discussed so many times that I sound like a broken record: http://www.914world.com/bbs2/index.php?sho...p;#entry1470608 |
ETMracing |
Dec 11 2013, 12:48 PM
there are benefits of a return line thats how the factory did it and it does keep the fuel cooler and thus adds power here is a thread with diagrams its been discussed so many times that I sound like a broken record: http://www.914world.com/bbs2/index.php?sho...p;#entry1470608 yup been studying that thread, so its okay to run through the first carb and then out to the next? |
ETMracing |
Dec 11 2013, 12:52 PM
option B it is then, thanks !!
stugray |
Dec 11 2013, 04:58 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I used:
Fuel cell (tank), filter #1, holley (red) pump, pressure regulator (all in front trunk), fuel pressure gauge (in engine bay) @ splitter, see-thru fuel filter at each carb, feed to each carb, No return. Plan on removing the cheap see-thu filters@carbs before racing (but they really help with startup when you leave the car sitting for a few weeks without firing up - you can see when the bowls are full) |
r_towle |
Dec 11 2013, 06:05 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Lo-Fi Version | Time is now: 29th May 2024 - 03:30 AM |
