> 2.7 crank and rods question
Peashooter
post Dec 11 2013, 12:12 PM
The crankshaft and rods for a 2.7 engine I have are apart and since I don't have any notes with it, I don't know which rod went on which journal. Assuming new bearings, does it matter?
Replies(1 - 2)
SLITS
post Dec 11 2013, 03:09 PM
"This Utah shit is HARSH!"
As I remember, they are not offset in any manner to be number 1 through 6 positions. It would be highly important that the rod cap is mated to the rod it came off of ... there should be numbers or markings on the side of the end of the beam and cap that match.
gothspeed
post Dec 11 2013, 04:58 PM
The way I recall if they are not yet precision balanced. You can weigh each of them, then put them into pairs, lightest to heaviest pairs. Installing the heaviest pair opposite each other starting at the flywheel. then the next lightest pair opposite each other, then the lightest pair.
You can even put the heavy one of the next pair to offset the weight of the lightest one of the previous pair. this works fairly well and can get you within a 'balanced spec' if planned well. Especially if you coordinate with the heavy parts of an unbalanced crank and flywheel ..... (IMG:style_emoticons/default/smile.gif)
Of course this does not work for parts that have never been used (new) and are way off, but can work for parts already in the 'ball park'.
- Lo-Fi Version Time is now: 13th July 2025 - 07:29 PM
