> Porsche 914 Information Please, Posting this for Francis
JeffBowlsby
post Dec 16 2013, 11:43 PM
Hi
Perhaps you can assist me - I'm buying my first 914.
It's a 1973 porsche 2.0 with appearance package .
My question is there's allot of people selling 1.7 1.8 and 2.0
Did some searching and not very clear .
How would I know that the 914 engine is 2.0 ????
And where and how do you match the engine to the body etc.?
Even the original factory color to the car !
And I heard 2.0 is made by porshe father Volkswagen ? Is that correct ?
Excuse my ignorance on the questions I like the 914's
But don't really know much about engines , me ahn is etc!
Thank you in advance for your time ...
Regards
Francis
Replies(1 - 5)
Jeffs9146
post Dec 17 2013, 01:14 AM
Ski Bum
The 2.0L is a Porsche built motor (unless it has been modified) all others except the 2.0L-6 are VW!
The 2.0L intake on the Porsche heads are 3 bolt and the intake on the VW are 4 bolt.
johannes
post Dec 17 2013, 06:14 AM
Club Porsche 914 France member since 2005
Region Association: France
The 2.0 engine was engeniered by the Porsche racing departement but manufactured by VW.
DBCooper
post Dec 17 2013, 07:46 AM
14's in the 13's with ATTITUDE
There are different injection systems on different engines and years and other external things, but it's difficult to know what's inside an engine because parts could have been changed over the years. That's the reason for Jeff's "unless it's been modified" comment, since after 40 years there aren't many engines that haven't yet been re-built, so potentially modified. The only dependable external tell is the three bolt heads of the 2.0 liter engine. The 2.0 engine used three bolts to attach the intake manifolds to the heads, the 1.7 and 1.8 engines used four bolts, one on either side of each intake runner. But even that isn't definitive, since the 1.7 and 1.8 heads can be installed on a 2.0 liter engine, and vice-versa, the 2.0 liter parts can be used with a smaller case. Or VW T4 car or bus engine parts could have been installed in the engine. So you have to either take the owners word or, to be certain, actually take the engine apart.
There's a good set of engine and part number identifiers at http://www.tunacan.net/t4/index.shtml, look at the "reference" tab, then "crankcase" or "cylinder head" or whatever part you have, to identify where it came from, what it is. But obviously that isn't helpful until the engine's apart.
For colors, equipment, options, etc. check in the Pelican Parts Tech pages, http://www.pelicanparts.com/914/914world.htm. He might be especially interested in starting at the "buying a 914" guide there, which has a lot of the info he'll need and links.
ky914
post Dec 17 2013, 07:56 AM
I thought I had a 2.0 since that was the badge on the back. However, I learned that I actually have a 1.7 from the engine number.
If the engine starts with W, EA or EB, it is a 1.7. EC is the 1.8. GA and GC are the 2.0 4 cylinders.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1227.photobucket.com-16328-1387288596.1.jpg)
larryM
post Dec 17 2013, 02:42 PM
emoze
VW bus also had a type4 2.0 - but it uses the heads with small valves, and has SQUARE exh ports
other than that you can have a type4 2.0 motor real cheap from pick'n'pull, and just bolt on your 914 heads
or - once upon a time - somebody actually made an adapter to fit the vw exh port to a 914 oval - i had a set long ago - long since sold
- Lo-Fi Version Time is now: 11th July 2025 - 01:34 PM
