Pulling trany, leaving engine in car, Any V8 guys done it? |
aircooledboy |
Dec 30 2004, 12:26 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Hey doods,
Gonna pull the trans this weekend on the 8 so it can enjoy a little leisure time with Brad Mayeur, and come back bigger, healthier and stronger. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) I'd like to yank the trans and leave the engine in. I understand that the engine needs to be supported since the trans provides the rear support. I have a few ideas, but I am curious if anybody has done this, and if so, how. Tanks (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
BIGKAT_83 |
Dec 30 2004, 12:45 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
If you feel right in the middle of the rear firewall engine side there is a hole. I cut this hole all of the way thru and welded in a tube,then made a L shaped braket that mounts on the back of my SBC engine on the top bell housing bolt hole. When removing the transaxle you mount the L shaped bracket and then lower the engine a small amount and you can remove the transaxle.
Bob |
BIGKAT_83 |
Dec 30 2004, 12:53 PM
Or you could also use a few tiedown straps to hold it in.
Bob Attached image(s) |
restore2seater |
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
Hey Chris,
When are you going to be at Brads? I was looking at a car he had there last week. He also had someones car from Chicago that had a turbo in it. What all are you going to have done? |
Mueller |
Dec 30 2004, 01:21 PM
did that a few years ago....of course the car used the red dawg engine mount cradle so removing the transmission was a piece of cake...even with the regular conversion mounts, it should be no problem, just make sure you support the motor from underneath
Sammy |
Dec 30 2004, 01:30 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
i did it, piece of cake.
I left the engine mounts in place put a jack under the back of the engine. i unbolted the tranny from the engine and then unbolted the rear tranny mounts being careful to support everything. Then i bench pressed the tranny and rested it on my chest, then rolled it over on the ground next to me. I had it out, replaced the main seal, and re-installed and had it running in an hour and a half. |
aircooledboy |
Dec 30 2004, 02:48 PM
As always: YOU GUYS ROCK!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Bob, I may look at the bracket idea later, but the ties downs look like the way to go for this time. Being a mostly lazy bastard, that is exactly what I was thinking about anyway. Your picture answers my main question, which was what to secure them to. Looks like targa clamp holes be da answer. Pat, I am going down January 15th to take my daughter to a trampoline meet in Peoria, so I will be killing 2 birds with one stone. Going to get a taller 5th, and anything else Brad thinks needs doing while he's in there. Thanks again boys. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:45 AM |
