Here is a view you don't see often, Where the heat ex meets the body |
URY914 |
Dec 30 2004, 05:23 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I was cutting a grinding and I just had to cut that duct for the heater out of the body. There was filler all over it as you can see. I used my grinder to cut it off flush with the sheetmetal.
Attached thumbnail(s) |
URY914 |
Dec 30 2004, 05:25 PM
Than I cut and welded in a piece of sheet metal to cover the opening.
URY914 |
Dec 30 2004, 05:27 PM
A little bondo and primer and it don't look too bad. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
URY914 |
Dec 30 2004, 05:30 PM
It took about a hour start to finish. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
736conver |
Dec 30 2004, 05:32 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
So what thats...... about a pound of filler. Getting lighter (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Chris Julian |
Dec 30 2004, 05:33 PM
Member Group: Members Posts: 159 Joined: 19-March 04 From: SF Bay area Member No.: 1,821 |
Not sure you lost any wieght with that mod. Although you did fix a problem/hidden rust spot. What's the little disc of steel in the dimple for?
Chris |
URY914 |
Dec 30 2004, 05:38 PM
Not everything I do reduces the weight, its a problem area that needed to be cleaned up. Ever stick a shop vac hose in that duct? I clean out 2 pounds worth of crap. Sharp eye. The disc is where I'm attaching my strut from the inner ear. Some people weld it at the bottom edge of the floor pan. |
brant |
Dec 30 2004, 05:42 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Paul,
that is exactly where my old race car has the strut mounted for the inner ear... a very good place brant |
SirAndy |
Dec 30 2004, 05:43 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
that "dimple" is actually a pretty strong area. that's where the 2 halves of the firewall connect. everything else around it is hollow ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Chris Julian |
Very smart. With the added plate you now have three pieces of metal supporting the rod end. Hopefully the firewall will provide enough lateral stiffness and not just float with the ear.
Chris |
Chris Julian |
Dec 30 2004, 05:49 PM
Here's how I supported my ear(s). Not sure teh plate is low enough?
Chris Attached thumbnail(s) |
URY914 |
Dec 30 2004, 06:01 PM
Does the engine mounting bar become a stressed member when it is installed?
URY914 |
Dec 30 2004, 06:04 PM
I think it will. The fire will is two pieces of sheet metal about a 1/2" apart. Than they come together at that dimpled spot. I don't have the HP or corning forces you have. |
Chris Julian |
Dec 30 2004, 06:08 PM
Yes. The rectangular bar accepts another rectangular bar that bridges the engine bay and mounts the SBChevy.
Chris |
DJsRepS |
Dec 31 2004, 07:22 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
How about a pic of the drive train going into that well designed Tub, I bet Its as kick ass as the car! 6cyl 911 motor?
Lo-Fi Version | Time is now: 9th June 2024 - 11:51 PM |
