Fresh Air Grille? |
Fresh Air Grille? |
Kaduku |
Jan 2 2014, 08:43 PM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
How do you install one of those plastic fresh air grilles?
914Sixer |
Jan 2 2014, 09:34 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You need the rubber gasket that is special for the grill. New ones are not available. Most used ones are in poor shape at this point.
Mike Bellis |
Jan 2 2014, 09:47 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
You unbolt the fresh air box and insert it.
You may have to remove the fuel tank for access... (IMG:style_emoticons/default/sad.gif) |
Kaduku |
Jan 2 2014, 10:32 PM
What! I guess I can forget this plan. |
NORD |
Jan 2 2014, 11:11 PM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
I've never had to remove gas tank. Couple of bolts on the sides of air box and it will drop down to slide grill in.
Old Yella |
Jan 2 2014, 11:54 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
I just ordered the late fresh air box seal which takes the plastic screen from 914 Rubber. you must specify you need the late version as the early cars didn't have the screen.
Kaduku |
Jan 3 2014, 12:00 AM
GaroldShaffer |
Jan 3 2014, 08:05 AM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Yes is they do.
Lo-Fi Version | Time is now: 2nd June 2024 - 09:52 AM |
