Is there a dummy's explanation to set flywheel offset |
rosenfe |
Jan 4 2014, 10:58 AM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
Changing flywheel out for a good used one.
bdstone914 |
Jan 4 2014, 11:10 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What do you mean my offset ? Crank end play?
That is controlled by the shim pack in back of the main seal. You need three shims that allow the correct amount of end play. I think it is about .004- .007". |
rosenfe |
Jan 4 2014, 11:16 AM
What do you mean my offset ? Crank end play? That is controlled by the shim pack in back of the main seal. You need three shims that allow the correct amount of end play. I think it is about .004- .007". Yes end play,how do I measure it .ive read info on pelican and auto Atlanta.i need a picture |
rosenfe |
Jan 4 2014, 01:03 PM
stugray |
Jan 4 2014, 01:38 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
http://www.ephotomotion.com/914engine/page15.html
(IMG:http://www.ephotomotion.com/914engine/images/80%20-%20crank%20end%20play.jpg) checkout his entire build thread. That is jut a tiny part of his build |
rosenfe |
Jan 4 2014, 03:23 PM
http://www.ephotomotion.com/914engine/page15.html (IMG:http://www.ephotomotion.com/914engine/images/80%20-%20crank%20end%20play.jpg) checkout his entire build thread. That is jut a tiny part of his build thats what i neede,this forum is great,thanks. |
stugray |
Jan 4 2014, 03:39 PM
Although I did it the other way around where my dial indicator was attached to the case and the tip was against the flywheel.
That way I was able to check the runout (out-of-flatness) of the flywheel too |
rosenfe |
Jan 11 2014, 04:25 PM
finally pulled engine and trans,didnt break anything,not as hard as i feared.flywheel teeth are all chewed up,as well as teeth on new starter.i took drivetrain out to replace flywheel,as it was making a really bad screech on startup.what could account for such wear on teeth of flywheel.? |
r_towle |
Jan 11 2014, 04:52 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Take out the spark plugs and see how freely the motor turns using a flywheel bolt to turn it, or even better, just turn it be hand via the flywheel.
Does it turn freely, all the way around 4 times? |
Mark Henry |
Jan 11 2014, 05:01 PM
You can get one of these, once on you just use your feeler gauge to set the end play, I've checked mine with mitutoyo dial indicator it's dead nuts on.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.greatplainsas.com-26-1389481295.1.jpeg) Set endplay .003 to .006, I always aim for .003 but not a hair under. finally pulled engine and trans,didnt break anything,not as hard as i feared.flywheel teeth are all chewed up,as well as teeth on new starter.i took drivetrain out to replace flywheel,as it was making a really bad screech on startup.what could account for such wear on teeth of flywheel.? Is this a bosch starter? sounds like it's sitting in too deep, not deep enough when it engauges or the starter bearings are shot. |
rosenfe |
Jan 11 2014, 07:21 PM
You can get one of these, once on you just use your feeler gauge to set the end play, I've checked mine with mitutoyo dial indicator it's dead nuts on. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.greatplainsas.com-26-1389481295.1.jpeg) Set endplay .003 to .006, I always aim for .003 but not a hair under. finally pulled engine and trans,didnt break anything,not as hard as i feared.flywheel teeth are all chewed up,as well as teeth on new starter.i took drivetrain out to replace flywheel,as it was making a really bad screech on startup.what could account for such wear on teeth of flywheel.? Is this a bosch starter? sounds like it's sitting in too deep, not deep enough when it engauges or the starter bearings are shot. starter bearings were shot |
Lo-Fi Version | Time is now: 10th June 2024 - 01:47 AM |
