You can get one of these, once on you just use your feeler gauge to set the end play, I've checked mine with mitutoyo dial indicator it's dead nuts on.
Set endplay .003 to .006, I always aim for .003 but not a hair under.
QUOTE(rosenfe @ Jan 11 2014, 05:25 PM)
finally pulled engine and trans,didnt break anything,not as hard as i feared.flywheel teeth are all chewed up,as well as teeth on new starter.i took drivetrain out to replace flywheel,as it was making a really bad screech on startup.what could account for such wear on teeth of flywheel.?
Is this a bosch starter? sounds like it's sitting in too deep, not deep enough when it engauges or the starter bearings are shot.
starter bearings were shot
