| Elliot Cannon |
Jan 6 2014, 05:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
After getting my heads rebuilt I am Finally getting around to putting my engine back together. Can anyone recommend a good (easy) way to clean the carbon deposits off the heads? Can this be done OK without removing the cylinders?
| SLITS |
Jan 6 2014, 05:57 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Put it back together ... fire it up and pour a cup of water slowly down the intake(s) at 2000 RPM .....
or in your case Fine wine! |
| jimkelly |
Jan 6 2014, 06:29 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
is oven cleaner NOT safe ?
| r_towle |
Jan 6 2014, 06:34 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Put it back together ... fire it up and pour a cup of water slowly down the intake(s) at 2000 RPM ..... or in your case Fine wine! (IMG:style_emoticons/default/agree.gif) Except the wine suggestion. Oven clean is not safe inside a motor....no no no you can use it outside, but I would not do it. A wire wheel also works. |
| 76-914 |
Jan 6 2014, 07:24 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
(IMG:style_emoticons/default/agree.gif) w/ Schlitz. squirting it in with a bottle doesn't kill the engine as easily. Glad to see you back. I was beginning to think those "old charges" were brought up against you. (IMG:style_emoticons/default/stirthepot.gif)
| Elliot Cannon |
Jan 6 2014, 08:20 PM
(IMG:style_emoticons/default/agree.gif) w/ Schlitz. squirting it in with a bottle doesn't kill the engine as easily. Glad to see you back. I was beginning to think those "old charges" were brought up against you. (IMG:style_emoticons/default/stirthepot.gif) Three arrests, NO convictions. (IMG:style_emoticons/default/flag.gif) |
| Elliot Cannon |
Jan 6 2014, 08:23 PM
Put it back together ... fire it up and pour a cup of water slowly down the intake(s) at 2000 RPM ..... or in your case Fine wine! Your $hitin' me right? (IMG:style_emoticons/default/dry.gif) Water down the intake? How about a small brass wire wheel? Will that work OK? I don't want to damage the top of the piston. Is that even possible? |
| yeahmag |
Jan 6 2014, 08:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Water does work, but a squirt bottle works better. Just keep from stalling it.
| r_towle |
Jan 6 2014, 08:37 PM
High pressure steam cleaning.
Google it, it has worked since before slits was born. |
| euro911 |
Jan 6 2014, 08:43 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
We use to de-carbonize using water while on a dyno (on running engines)
Pull the jugs off one at a time, stuff rags on the case opening and wheel them. You don't want to nick the tops of the cylinders. |
| SLITS |
Jan 6 2014, 08:55 PM
We use to de-carbonize using water while on a dyno (on running engines) Pull the jugs off one at a time, stuff rags on the case opening and wheel them. You don't want to nick the tops of the cylinders. No wire wheel marks on the top of the piston either. Water works or Brake cleaner & rags |
| r_towle |
Jan 6 2014, 09:00 PM
My concern with any type of wire wheel is all my wire wheels get smaller with time and use, and eventually there are no wire pieces left.....so they go somewhere, and you might get one lodged into the side of the piston, just laying on top of a ring, and you won't see it.
Then you know what it might do... Use water or rags and cleaner. |
| StratPlayer |
Jan 6 2014, 09:06 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,361 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
| jeffdon |
Jan 6 2014, 09:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Put it back together ... fire it up and pour a cup of water slowly down the intake(s) at 2000 RPM ..... or in your case Fine wine! Your $hitin' me right? (IMG:style_emoticons/default/dry.gif) Water down the intake? How about a small brass wire wheel? Will that work OK? I don't want to damage the top of the piston. Is that even possible? Hey Elliot....How many miles on that motor? I had about 8k on mine, and had some nasty carbon, but my plugs have always read a nice mixture. How much carbon and how fast the build up is natural? |
| SLITS |
Jan 6 2014, 09:47 PM
Ok Av8tor .... The water hitting the hot cylinder flashes to steam instantly, creating a shock which cracks the carbon deposits. They chip off and go down the exhaust.
As I remember your pic, the deposits are shiny, like being wet. Looks like oil. Try the Brake cleaner first and see if the deposit dissolves somewhat easily. |
| McMark |
Jan 7 2014, 01:34 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Why bother? Or are you planning on tearing down the engine to clean the pistons before each Concours event? (IMG:style_emoticons/default/av-943.gif)
Seriously, everything you clean will be back on there in short order. Don't waste your time. |
| Elliot Cannon |
Jan 7 2014, 02:12 AM
Why bother? Or are you planning on tearing down the engine to clean the pistons before each Concours event? (IMG:style_emoticons/default/av-943.gif) Seriously, everything you clean will be back on there in short order. Don't waste your time. OK! Now this is an answer I can live with. (IMG:style_emoticons/default/biggrin.gif) |
| ConeDodger |
Jan 7 2014, 06:58 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Why bother? Or are you planning on tearing down the engine to clean the pistons before each Concours event? (IMG:style_emoticons/default/av-943.gif) Seriously, everything you clean will be back on there in short order. Don't waste your time. OK! Now this is an answer I can live with. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) |
| Mark Henry |
Jan 7 2014, 09:29 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
As a builder I've never liked the water trick... (IMG:style_emoticons/default/dry.gif)
Wait a second...bent rods = more work (IMG:style_emoticons/default/idea.gif) Nevermind....carry on.... (IMG:style_emoticons/default/smash.gif) |
| Matt Romanowski |
Jan 7 2014, 09:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
McMark is right. If you're not taking it all the way apart, leave it alone. You're only going to get more crap in the motor and oil. That is not an excessive amount of carbon and will be back after about 10 minutes of running.
Lo-Fi Version | Time is now: 2nd April 2026 - 09:20 AM |
