transmission question |
last337 |
Jan 10 2014, 06:04 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
So I finally pulled motor so I can start cutting rusted areas. I want to put motor on stand but I neglected to drain tranny of gear oil before removing from car. I was going to pick it up and drain all fluids and separate it from engine but I remember something on here about making sure of something before I drain it but I can't find info. What is the concern? Also what should I expect to do to pull tranny from motor?
yeahmag |
Jan 10 2014, 06:12 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Make sure you can open the fill plug first.
last337 |
Jan 10 2014, 06:59 PM
I can't find any articles describing the replacement process on a side shift transmission. Does anyone have a link to one? Also, I have no idea what size the fill plug is. I know I don't have that size allen key socket. Can anybody tell me what size it is so I don't have to buy more than one? I also can't find an image of the drain plug on this one
ThePaintedMan |
Jan 10 2014, 07:09 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
The right side of the transmission (in the orientation of it being installed in the car) has two 6-point plugs. The top is the fill, the bottom is the drain. You need a 17 mm hex socket to fit those.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.calgaryautoworks.com-13527-1389402568.1.jpg) Removal is very easy. If it's out of the car already, just unbolt the 3 nuts on the four corners at the front of the transmission holding it to the engine and remove the starter. That's it. (IMG:style_emoticons/default/beerchug.gif) |
mrbubblehead |
Jan 10 2014, 08:42 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
sometimes a propane torch will help the stubborn ones.
last337 |
Jan 10 2014, 08:57 PM
Thanks! They both appear to be in good shape so hopefully they come out easy. Now that motor is out its almost time to start cutting. Made a brace for door to hold things straight. Not sure if it will rack much. May weld a piece of 1/2" pipe along side of turnbuckle once I get adjusted a few turns pushing out to hopefully give some lateral support.
TheCabinetmaker |
Jan 10 2014, 08:58 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You don't need a list. Do like george said then pull.
Don't need to drain fluid. It won't come out if you leave it laying down. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:06 AM |
