> Tarret Sway Bar install, Argh....
jrrhdmust
post Jan 15 2014, 11:09 AM
So I decided i would start drilling the holes for my Tarret front sway bar. I had downloaded the instructions from Pelican parts read through them a few times. I cut out the template and marked my holes. I drilled the bottom hole, and got the bright idea, that I would put bolts in the Tarret backing plate to verify and check my holes.
Much to my surprise my hole was wrong....then it dawned on me the Pelican parts instructions were for a stock sway bar...mine was Tarrett... (IMG:style_emoticons/default/headbang.gif)
So now my 2 minute hole is going to cost me about 4 hours of welding and grinding to build a tiny plate to weld the hole shut.... (IMG:style_emoticons/default/headbang.gif)
And all i had to do was match the template to the part and save me all of the trouble..... (IMG:style_emoticons/default/blink.gif)
Replies(1 - 9)
Harpo
post Jan 15 2014, 06:32 PM
I also have the Tarret sway bar and I also used the instructions from pelican and mine went together just fine. My holes are located at 2:00, 6:00 & 10:00.
David
jrrhdmust
post Jan 16 2014, 08:54 AM
The template from pelican is larger - like a 1/2 in per hole, than the tarret parts I received. I will post pics tomorrow.
jpnovak
post Jan 16 2014, 01:46 PM
They call me "Nanoman"
Bummer. Sounds like your template did not print to size. The Tarrett and stock factory mounts are the same dimension. The through body sway bars are all the same for 911, 912 and 914.
Eric_Shea
post Jan 16 2014, 04:03 PM
PMB Performance
I don't think I'd worry about it, when you weld in the backing plate you can cover the hole and weld the extra then.
P.S. Why didn't you just use the backing plate as the template?
jrrhdmust
post Jan 17 2014, 12:11 PM
Ding ding ding we have a winner, the template didn't print to size. (IMG:style_emoticons/default/wacko.gif)
I am really gald I checked the template with the backing plate before I drilled all three holes. I did see the 1 inch call out and it didn't dawn on me to check it....
post Jan 17 2014, 01:05 PM
Resident German
QUOTE(jrrhdmust @ Jan 17 2014, 10:11 AM) *
More often than not, the default for printing mode is "Scale size to fit media" in which case who knows what size you'll end up with.
Been there, done that ...
(IMG:style_emoticons/default/dry.gif)
r_towle
post Jan 17 2014, 03:32 PM
Custom Member
where to start...
Your first mistake was reading the directions....
Did your Dad not teach you that part of manhood...
NEVER read the directions.
Second...
Well , nevermind, the first was enough.
rich
Socalandy
post Jan 17 2014, 10:57 PM
Its got to be Yellow!!!
QUOTE(jrrhdmust @ Jan 15 2014, 09:09 AM) *
As Master Rick would say, Flatten a section of copper pipe, Back up the hole and plug weld it. The weld wont stick to the copper (IMG:style_emoticons/default/biggrin.gif) you have to cut the slot on the inside for the backing plate anyways
sixnotfour
post Jan 17 2014, 11:22 PM
drop it down another 1/4 to insure no rubbing on gas tank
- Lo-Fi Version Time is now: 30th October 2026 - 08:39 PM
