Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
After looking around and only finding a Volvo guy that had these, And looking at what it takes to make these I decided that these needed to be addressed.
You pay more for just one, but now you can get all 4 for less! These are in production and will be ready in about 14 days. So if you want these just post here, and ill let you know when they are ready. -Mark Attached image(s) ![]() |
Mikey914 |
More
Mikey914 |
One more
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,156 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I need a gross of these.
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Looked but could not find a tutorial on how to replace the boots. Is there one on how to remove the connectors to slide the new boot on? Any help would be appreciated.
Niklas |
Porsche 914 Sweden ![]() ![]() Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia ![]() |
What is the price ?
rmital |
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 ![]() |
914werke |
Requires a very small, slight flat blade tool like a jewelers screwdriver to depress the locking tab on the female blade connector.
You can then remove the plastic plug end, install the boot, re-bend the locking tabs, insert the blade connectors back into the plug & Viola! |
no1uno |
Member ![]() ![]() Group: Members Posts: 206 Joined: 2-December 10 From: Melbourne, FL Member No.: 12,448 Region Association: South East States ![]() |
I'll take a set
Niklas |
I take 3 set.
Niklas |
David_S |
Member ![]() ![]() Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region ![]() |
Just in time because I need a set !!! Put my name on the list please !!!!
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I'll take a set.
--- Rob |
luskesq |
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California ![]() |
I'll take two (2) sets Mark. Thank you.
Keith |
McMark |
The two pole connectors that go with these would be handy. AFAIK, they are not available. (IMG:style_emoticons/default/shades.gif)
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
This is just for the small early connectors right?
The later L-jet style conector didn't have these...or did they? |
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
Two sets.
Thanks for doing this stuff. |
Mike D. |
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None ![]() ![]() |
I'd take 4 sets
thanks! |
McMark |
Yeah, Mark. Early only. If your fuel injection harness has small white plastic connectors at the injectors, these are for you.
Mikey914 |
I did make these a little softer (more stretchy), so they may work for both.
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I am in for a set.
Thanks (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 01:21 PM |
