| jeeperjohn56 |
Jan 16 2014, 05:56 PM
Member ![]() ![]() Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Okay guys, need to install a passenger side mirror on my white car and don't want to screw up the door. Does anybody have the measurement on where too put it? This will be a stock 914 mirror. Any picture's would be appreciated. Thanks John (IMG:style_emoticons/default/driving.gif)
| type47 |
Jan 16 2014, 06:23 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Take the door panel off and find the nuts for the mirror screws that are welded on the inside of the door skin (?, the door metal). try to get a punch/nail/drift/something that will be able to make an outward dimple on the door skin when you tap it. locate the nail/drift thingy in the hole where the threads are in the nut, center as best you can, then tap gently to try to get a slight raised outward mark on the outside. When both are marked, go to the outside of the door skin and carefully drill the hole where the mark is. You might end up re-dimpling the skin on the outside so the drill bit doesn't walk around on your nicely painted door skin. You can start with small holes and gradually open it up until it's the correct size (6mm if I recall). Paint hole and area to prevent rust. The screws are supposed to be 6mm oval head Phillips; I found flat head 6mm Phillips at local hardware store. There is also a base gasket between the mirror base and the door skin.
| toolguy |
Jan 16 2014, 06:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
IIRC, the nuts are already welded inside the door frame. . you need to pull the inside panel and punch up through the nuts to mark the outside. then drill accordingly. .
| McMark |
Jan 16 2014, 07:23 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
In exactly the same place as the driver's side. Drill the one close to the vertical chrome piece first because I find it easier to locate. Then once you have that one done, install the mirror with one screw and use a sharpie to make the other one.
The nuts are already in there, so don't drill too far. Just one layer of sheet metal. Go slow and check your progress often. |
| dlkawashima |
Jan 16 2014, 08:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Like Jim said, I would remove the door panel, locate the two nuts that are welded in place, and stick a punch through each hole to create little pimples on the outside door skin.
BTW, this question has been asked before and the punch that's most often recommended is one of those automatic center punches that you can find at any hardware store, or even Amazon. You won't have to swing a hammer in a confined space if you use an automatic punch. When drilling, I recommend starting with a small bit and work your way up to the size you need to fit the screws through the holes. http://www.amazon.com/TEKTON-6580-Automati...h+spring+loaded (IMG:http://www.914world.com/bbs2/uploads_offsite/ecx.images-amazon.com-12234-1389925413.1.jpg) |
| PanelBilly |
Jan 16 2014, 08:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
HF has the punches for a couple of bucks and if there's a sale even cheeper
| sfrenck |
Jan 17 2014, 07:34 AM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
I did mine last fall. The nuts are there - I just carefully measured the driver mirror hole locations and used a small bit for a pilot hole to make sure I was in the right spot. I didn't have a punch - and didn't need one.
| worn |
Jan 17 2014, 11:24 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Okay guys, need to install a passenger side mirror on my white car and don't want to screw up the door. Does anybody have the measurement on where too put it? This will be a stock 914 mirror. Any picture's would be appreciated. Thanks John (IMG:style_emoticons/default/driving.gif) I found that careful measurements from what you have on the driver will get you there. Start with the smallest bit you can find and see if the hole lands in or on the nut. Adjust accordingly. Drill to size with a countersink bit so you don't destroy the nut. Have fun! It may be that one of the nuts can be located from the inside without pulling the door panel; I just don't remember. I do remember it went well. Of course if you miss, you can call them lightening or "speed" holes. Yeah, great. |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:50 AM |
