| Elliot Cannon |
Jan 17 2014, 03:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
When I removed these, the slot was facing up. The book says they should be facing down. (IMG:style_emoticons/default/confused24.gif) Which is correct? Does it matter? If facing up is wrong, they have been like that since I installed ceramic lifters about 9 years ago. (IMG:style_emoticons/default/WTF.gif) If there is a way to eff this up I will find it. (IMG:style_emoticons/default/laugh.gif)
| Java2570 |
Jan 17 2014, 03:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Yep, the slots face down....that's where the push rod tube retainers fit into.
| 76-914 |
Jan 17 2014, 03:13 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
IIRC, down. Of course I don't remember what I had for breakfast and all my wrenching has been Suby for 12 month's. (IMG:style_emoticons/default/dry.gif)
| brant |
Jan 17 2014, 03:18 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,179 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
the slot holds the spring...
the spring holds the push-rod tube and the ankle bone is connected to the ......... |
| r_towle |
Jan 17 2014, 03:24 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
down
| reharvey |
Jan 17 2014, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
So---you have no pushrod tube retaining springs! Not good...................
| brant |
Jan 17 2014, 03:30 PM
hey if you use enouch RTV... its all good.
| r_towle |
Jan 17 2014, 03:34 PM
| 0396 |
Jan 17 2014, 04:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
The side that face down plus the larger" pad" side also face head.
| sixnotfour |
Jan 17 2014, 10:00 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,199 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
type4sale
| Elliot Cannon |
Jan 17 2014, 11:36 PM
| Elliot Cannon |
Jan 17 2014, 11:37 PM
| Dave_Darling |
Jan 18 2014, 01:43 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
| wndsrfr |
Jan 18 2014, 07:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,461 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
the slot holds the spring... the spring holds the push-rod tube and the ankle bone is connected to the ......... The slots hold the spring. I don't use a spring. So I guess it doesn't matter then, if they are up or down if not using a spring? Hmmmmm..........just wondering, who does the work on your airplane engine? (IMG:style_emoticons/default/av-943.gif) |
| 76-914 |
Jan 18 2014, 08:36 AM
Do you need a set of springs?
Lo-Fi Version | Time is now: 16th April 2026 - 12:51 AM |
