Full Version: Valve rocker shaft
Elliot Cannon
When I removed these, the slot was facing up. The book says they should be facing down. confused24.gif Which is correct? Does it matter? If facing up is wrong, they have been like that since I installed ceramic lifters about 9 years ago. WTF.gif If there is a way to eff this up I will find it. laugh.gif
Java2570
Yep, the slots face down....that's where the push rod tube retainers fit into.
76-914
IIRC, down. Of course I don't remember what I had for breakfast and all my wrenching has been Suby for 12 month's. dry.gif
brant
the slot holds the spring...
the spring holds the push-rod tube
and the ankle bone is connected to the .........
r_towle
down
reharvey
So---you have no pushrod tube retaining springs! Not good...................
brant
hey if you use enouch RTV... its all good.
r_towle
QUOTE(brant @ Jan 17 2014, 04:30 PM) *
obviously, he did not use enough during the last build, so he needs to do it again.
Time to buy stock in 3m....Elliott is building a motor...
rich
0396
The side that face down plus the larger" pad" side also face head.
sixnotfour
type4sale
Elliot Cannon
QUOTE(brant @ Jan 17 2014, 01:18 PM) *
The slots hold the spring. I don't use a spring. So I guess it doesn't matter then, if they are up or down if not using a spring?
Elliot Cannon
QUOTE(r_towle @ Jan 17 2014, 01:34 PM) *
rich
Helpful as always. Thanks.
Dave_Darling
QUOTE(Elliot Cannon @ Jan 17 2014, 09:36 PM) *
So, no spring, rocker stands upside down, and tons of RTV.
Evidently you like smoking heat exchangers and/or oil leaks...
--DD
wndsrfr
Hmmmmm..........just wondering, who does the work on your airplane engine? av-943.gif
76-914
Do you need a set of springs?
