| Jon H. |
Jan 22 2014, 07:11 PM
Member ![]() ![]() Group: Members Posts: 242 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Will these affect the performance of a stock FI 2.0L engine negatively in any way?
Regards' Jon ![]() |
| Elliot Cannon |
Jan 22 2014, 07:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
K&N. One of Capn' Krustys' faves. (IMG:style_emoticons/default/av-943.gif)
| Jon H. |
Jan 22 2014, 07:44 PM
Yeah I know the K&N battle, but does anybody run these things? I'm more or less questioning the vacuum line hook ups and vacuum effecting FI performance. Not so much if K&N is a good air filter. Jon |
| Elliot Cannon |
Jan 22 2014, 08:36 PM
Yeah I know the K&N battle, but does anybody run these things? I'm more or less questioning the vacuum line hook ups and vacuum effecting FI performance. Not so much if K&N is a good air filter. Jon I used them on my 3.2 (yellow zonker) and I use them on my other car with Webers. Work fine for me. I'm sure others will disagree. But then again, I use high temp silicone to seal and secure my push rod tubes so what the hell do I know? (IMG:style_emoticons/default/av-943.gif) |
| Woody |
Jan 22 2014, 09:15 PM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
The only time I would use a K&N is when a paper filter won't fit an application. K&Ns allow bunches more air in but only because they filter less which also means they let in trash. If a K&N is your only option make sure you clean it regularly and keep it oiled. If its on a newer car that runs a MAF sensor a K&N will trash it in short order.
| 3d914 |
Jan 22 2014, 10:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Yeah I know the K&N battle, but does anybody run these things? I'm more or less questioning the vacuum line hook ups and vacuum effecting FI performance. Not so much if K&N is a good air filter. Jon Jon, Any of the lines forward of the throttle body are not vacuum - they're open to atmosphere. They should not affect FI performance. The only lines that can are those after the throttle valve. |
| boxsterfan |
Jan 22 2014, 10:33 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Aahhhh, the age old question of getting better air intake into the 914 engine.
I always wonder if you could get air piped in all the way from the front of the car. |
| MATTYLITE |
Jan 22 2014, 10:49 PM
Member ![]() ![]() Group: Members Posts: 104 Joined: 23-August 12 From: California Member No.: 14,843 Region Association: Southern California
We built a single intake system, and a dual intake system (pictured) for this application. This system has been proven on the track with multiple Porsche Owners Club class wins and perfect for the street as well.
(IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-14843-1390452573.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-14843-1390452573.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-14843-1390452573.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-14843-1390452573.4.jpg) |
| Dave_Darling |
Jan 23 2014, 10:07 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I'm more or less questioning the vacuum line hook ups and vacuum effecting FI performance. The FI doesn't really care exactly where its lines are hooked up. It just needs specific hoses to either be hooked to manifold vacuum, or to ambient-pressure (filtered) air. So as long as you hook up the hoses that used to go to the air cleaner to something "upstream" of the throttle body, you're fine. (The exceptions to only manifold vacuum or ambient air are the lines from the throttle body to the distributor dashpot. But those don't enter into this discussion anyway.) --DD |
| Socalandy |
Jan 23 2014, 11:01 AM
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
I ran K&N's on my 72 with 44 Webers and had a lot of issues with clogged idle jets so I added the K&N pre-chargers and that solved my issues. I'm going the same route for my -6
Attached thumbnail(s) |
| Jon H. |
Jan 23 2014, 01:12 PM
Thanks for the replies. Not sure though if I will make the purchase. After all, it really only looks better then the OEM filter housing.
Jon |
Lo-Fi Version | Time is now: 9th March 2026 - 06:36 PM |
