> Ideas, suggestions
computers4kids
post Jan 22 2014, 09:29 PM
Love these little cars!
Ever since I did my SBC conversion, I've never been happy with the sharp turn the 1 1/4 gate hose had to take from the water pump to follow the bottom of the car. When the hose is cold the turn actually causes the hose to kink, but once the pump pressurizes the system the hose fills out and unkinks.
Anyway, what I need to do is add a 90 degree turn either with some pipe or a formed piece of radiator hose. I would appreciate some ideas how you would approach this.
Ideally it would be nice to have a curved piece of pipe welded to outlet on the pump, but not even sure if you can. It's made of cast aluminum I believe. This would then only require one clamp where the pipe would join the hose.
Alternately, I could purchase a 90 degree radiator silicone elbow but then would also need a union tee and multiple places to clamp.
In an old posting, I saw that someone said that Renegade offered a 90 degree tee.
Ideas?
Replies(1 - 9)
ThePaintedMan
post Jan 22 2014, 09:47 PM
Why not take the elbow off and bring it to a radiator shop to have them weld you a 90 degree extension? You could mock up the bend that you require with some electrical conduit... or get it at least close enough to demonstrate what you desire. Good luck!
wildman
post Jan 22 2014, 09:49 PM
Usually when I have that sort of problem I go to my local parts store and ask if I can go in the back and look at their formed hoses. Then I will buy one where at least some portion has the right bend (or very close to it) and I'll cut off the excess. It looks cleaner that way IMO and there are fewer connections to leak
JRust
post Jan 22 2014, 10:26 PM
I have done it a couple ways. The formed hoses are good they just mean you need a sleeve (pipe) to make the transition between the 2. I've use the muffler pieces as you can use them as a reducer if need be too. Getting a pipe with a 90 bend that you can attach to the mount is a decent idea too. You just have more short hoses to deal with.
Oh & if you haven't considered making the trip to NM for Route 66. You should (IMG:style_emoticons/default/evilgrin.gif)
SLITS
post Jan 22 2014, 10:32 PM
"This Utah shit is HARSH!"
The are hoses made with a wire spiral in them to keep from collapsing under suction. They should be available at your local FLAPS.
And there is industrial hose that is designed to withstand hi-viscosity liquids under suction without collapse.
partwerks
post Jan 23 2014, 07:38 AM
That's what I did when I re routed my radiator lines, I went up and down the isles at the auto parts store, till I found a suitable candidate, and cut off the useless part, to get the section that would work for the application needed.
bulitt
post Jan 23 2014, 07:59 AM
Achtzylinder
Jim Kelly used a 90degree. Think he got it off ebay???
(IMG:http://www.914world.com/bbs2/uploads/post-2460-1383845430.jpg)
yup-
(IMG:http://www.914world.com/bbs2/uploads/post-2460-1380491473_thumb.jpg)
Phoenix-MN
post Jan 23 2014, 08:45 AM
NAPA had an online catalog of their hoses. It listed them by size and had over-all dimensions along with a drawing showing the shape. I couldn't find my bookmark for it but a little searching you should be able to find it.
jimkelly
post Jan 23 2014, 08:47 AM
Delaware USA
a better pic I just took.
computers4kids
post Jan 23 2014, 10:19 PM
Thanks all for your ideas. Jim, that's pretty much what I had in mind. The stainless tube that you purchased--seems to me to be the simplest, yet functional solution. I wasn't crazy about renegade's 90 degree fitting.
I'm pretty ignorant when it comes to what types of metals can be welded to another. Is it possible to weld that 90 degree tube to the actual cast aluminum outlet that bolts to the water pump?
Those tubes can be purchased from Speedway http://www.speedwaymotors.com/Shop/Hoses-a...t-Pipes/12.html for $16.99
Thanks,
Mark
- Lo-Fi Version Time is now: 14th April 2026 - 06:34 AM
