For those who care about 0-60 numbers, stock 914-6 test today |
mskala |
May 27 2003, 04:27 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Check the graph and data: this is repeatable, I don't seem to have a lot
of skill on the 'launch', especially without blowing my 33-year old trans. 0-60 in 8.4 seconds. 914-6 Timed Run Mark S. '70 914-6 |
Jeff Krieger |
May 27 2003, 04:35 PM
Unregistered |
Mark, I see that you finished making the timing device that you were talking about - well done! Can you make one with accelerometers now so that you can calculate hp and braking distances as well?
mskala |
May 27 2003, 05:42 PM
Yeah, this is the same box that I made more than
2 years ago. Never got around to making one with the accelerometers ala g-tech pro, but by the time I get to it they'll probably be in everybody's watches. (IMG:style_emoticons/default/biggrin.gif) So I'll never get to use your code. Mark S. '70 914-6 |
Jeff Krieger |
May 28 2003, 12:47 AM
Unregistered |
Just as well ... I'm sure a professional programmer would have a good laugh at my code but at least it produces very accurate results.
Chris914n6 |
Jun 3 2003, 04:47 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
what's this about a timing device???
is it a cheap DIY gadget after shopping at Radio Shack? curious conversion driver... Chris 914n6 |
need4speed |
Jun 3 2003, 05:53 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
QUOTE(Jeff Krieger @ May 27 2003, 10:47 PM) Just as well ... I'm sure a professional programmer would have a good laugh at my code but at least it produces very accurate results. Having worked in the software biz for 11+ years, I think a LOT of people would be VERY suprised at what passes for "professional" code. I think there's a reason Microsoft is opposed to opening their source. . . |
mskala |
Jun 3 2003, 06:28 PM
The box is a microcontroller and RAM chip, some
buttons and an LCD display. It takes the pulses from the points (I have a little cable coming off my optical points-replacement module). Takes 20 samples per second for 10 seconds (stupid me I could have put in enough memory for an hour). It's kinda expensive to just make one. About $150 in parts. But then I made the software so you could view a bunch of different things right there in the car without having to download first. It will store 3 different runs before you have to offload the data. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:31 AM |
