F/S cutting up a 73 pats car |
camikearo |
Feb 2 2014, 01:07 PM
I'm new here ... Group: Members Posts: 0 Joined: 2-December 13 From: pittsburgh pa Member No.: 16,708 Region Association: North East States |
(IMG:style_emoticons/default/sawzall-smiley.gif) cutting it up let me know what you need lots of other parts for sell as welll
Attached thumbnail(s) |
porsha916 |
Feb 2 2014, 01:29 PM
Member Group: Members Posts: 214 Joined: 1-June 04 From: Greenwood, SC Member No.: 2,137 Region Association: None |
hi, why are you cutting it up???
Take Care BILL |
camikearo |
Feb 2 2014, 01:32 PM
SpecialInt |
Feb 2 2014, 01:59 PM
Newbie Group: Members Posts: 6 Joined: 3-December 13 From: Maryland Member No.: 16,722 Region Association: None |
hi, why are you cutting it up??? Take Care BILL i bought these cars to part out and sell to fund another project of mine... they where basket cases and i didnt want to send alot of time and money to get them going again.. Pat will be upset that your cutting up his/her car. (IMG:style_emoticons/default/cheer.gif) |
shoguneagle |
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Make sure you are ready to cut. There may be parts still on the car(s) such as the electrical harness which may be worth saving if mostly intact; separate at the seams as much as possible to allow the sheet metal to be used; take out the r&P steering; just to mention a few items.
OF ALL THINGS, MAKE SURE SIR ANDY GETS THE VIN#S FOR HIS RECORDS. All parts are getting harder to find; instead of cutting up the "residual" try to sell them as a complete rolling chassis which is said assuming they are not full of rust and worthwhile passing on. Just a few of my thoughts. Steve |
carr914 |
Feb 2 2014, 03:20 PM
Racer from Birth Group: Members Posts: 118,970 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Do you have anything beside sheet metal - I'm looking for a 73 2.0 FI system
MassTeener |
Feb 2 2014, 04:48 PM
Newbie Group: Members Posts: 27 Joined: 25-December 10 From: Mass Member No.: 12,519 Region Association: North East States |
id like the small left & rght engine grill vents!
i see one just laying there thnaks |
ndtman |
Feb 2 2014, 06:03 PM
Newbie Group: Members Posts: 5 Joined: 19-June 12 From: Moorhead, MN Member No.: 14,580 Region Association: Rocky Mountains |
I don't know exactly what they're called, but I could use some sheet metal frame material from the passenger compartment. My rocker panels rusted through, and the lower part of the inside frame tunnels (that house the heating tubes on each side) need to be replaced. In your photos, you can see the brown heater hose coming out the top of them. They're about 45" x 3.5" x 7", and are spot welded to the outer edges of the floor. I was going to fabricate them and patch them in, but it would be easier if I could get good used ones instead. Let me know what you think.
914forme |
Feb 2 2014, 08:52 PM
So yes I would pull the front sway bar if I was you, they are worth a few bucks.
Other than that, I am out unless it does not work out for a part I am hoping to get out of cincinnati. |
CptTripps |
Feb 3 2014, 03:44 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I'm looking for this section. I can give you better measurements if you're willing to cut this piece for me.
Attached image(s) |
michael7810 |
Feb 3 2014, 03:25 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Please PM me if the front sway bar is available?
ndtman |
Feb 4 2014, 12:00 AM
This is the part I am inquiring about. I wasn't able to get a good photo of it in my car, so I downloaded one from this forum that shows the front half of the part I am asking about. I circled the part in green, although I also want the unshown back half of the part as well. I would want the few remaining inches of floor pan that extend outwards from this part to be included, as well as a few inches of the metal that it attached to front and rear. I for sure need to replace this on the drivers side, but will need to do a little more checking into the rust damage on the other side to determine if it needs replacing. What would it run for this to be cut out and shipped to me in 56560? |
camikearo |
Feb 4 2014, 06:14 PM
This is the part I am inquiring about. I wasn't able to get a good photo of it in my car, so I downloaded one from this forum that shows the front half of the part I am asking about. I circled the part in green, although I also want the unshown back half of the part as well. I would want the few remaining inches of floor pan that extend outwards from this part to be included, as well as a few inches of the metal that it attached to front and rear. I for sure need to replace this on the drivers side, but will need to do a little more checking into the rust damage on the other side to determine if it needs replacing. What would it run for this to be cut out and shipped to me in 56560? not a problem.. if i cut it, i will give you the whole outside into the floor.. if you can get me some messurements. or points to cut it at would be great... I'd ask 100-150 a side depending on how long / easy these are to remove.. does this sound fair? as for shipping i cant tell you untill i have it cut out and get size and weight of the box... but i will ship it to you for cost im not going to try and make money off shipping,.. i feel thats wrong. thanks and let me know |
puffinator |
Feb 4 2014, 09:02 PM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
What does the front of the car look like?
wndsnd |
Feb 4 2014, 09:07 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
how much for the passenger rear fender from the door sill back to at least rear of fender well?
rick 918-S |
Feb 4 2014, 11:39 PM
Hey nice rack! -Celette Group: Members Posts: 20,485 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What does the front clip look like? I am interested in complete front fenders Maybe the whole front clip.
euro911 |
Feb 5 2014, 05:28 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Also, if you're going to crush the remainder of the carcass, try to save little parts like the rubber fuel line and brake supply line grommets, rear proportional brake valve, front and rear tunnel access plates, etc. if they're in good condition. (IMG:style_emoticons/default/idea.gif)
rmdinmd |
Feb 5 2014, 07:06 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
what does driver door look like?
camikearo |
Feb 5 2014, 05:45 PM
What does the front clip look like? I am interested in complete front fenders Maybe the whole front clip. the front is clean.. except for the passangers fender it was in a crash, but damage is just in the outer sheet metal. i will get better pictures here as soon a weather lets me |
TeenerTim |
Feb 6 2014, 02:52 PM
Senior Member Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
If Rick doesn't take the fenders or the front clip I need the drivers side weather strip channel from mid-wheelwell down around the headlight to the front. Don't want to ruin a fender sale if you have one.
Lo-Fi Version | Time is now: 7th June 2024 - 02:55 AM |
