FS: Running Corvair 6 motor conversion- SOLD, As pulled from my 72 914. It's a runner & cheap 6 conversion |
JRust |
Feb 2 2014, 10:31 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
This is a cheap bolt in 6 conversion. Not sure on the HP numbers. Supposed to be around 110 in stock form. This has been reversed to work in the 914. Which is supposed to bump the hp a bit. It has dual weber 44's adapted to it which the weld job is less than stellar on. Here is a link to my thread on the car. There are multiple angle's & more info there
http://www.914world.com/bbs2/index.php?showtopic=213617 Price reduced -$1000 for the motor & conversion. Which include's dual exhaust, motor mount, Adapter plate, Flywheel & starter. Not sure if this flywheel is the same as a stock 914 one (tooth & diameter wise). The starter is also a custom welded job. This takes no custom modifications. It will bolt right in & go. I pulled the drivetrain to replace the suspension. Then got some parts for the motor. I bought, Valve gaskets, & new exhaust donuts to fix an exhaust leak. All will be included. While you can install this as is. I would buy it with plans to improve the carb setup. The welding on the heads is fugly even if it is functional. I don't think the weber 44's are really a good setup for them either. I'll leave what you do with it up to you. It really is a cheap way to get a six in there. Doesn't require a remote oil pump & is a very solid motor. Attached thumbnail(s) |
JRust |
Feb 5 2014, 11:41 PM
Wow not even a nibble yet? Didn't think I had it overpriced (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/icon_bump.gif) |
JStroud |
Feb 6 2014, 12:20 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Wow, surprised its still available, I thought it was a good deal. (IMG:style_emoticons/default/confused24.gif)
No way to get that HP for the $. Jeff |
Dr Evil |
Feb 6 2014, 08:09 AM
This is a great deal. If I lived closer it would be mine. I would Ebay it as you will reach less purists.
JRust |
Feb 12 2014, 12:01 PM
Heading to ebay after the weekend if nobody steps up interested. You seriously can't get this HP any cheaper. Replace your worn out 4 even temporarily while you build a big 4. Keeps you driving plus get's you more HP.
JRust |
Feb 17 2014, 10:50 PM
SOLD
Lo-Fi Version | Time is now: 1st June 2024 - 11:30 PM |
