Tranny issue, What are these and are they available ? |
jim_hoyland |
Feb 3 2014, 02:55 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I had been having some shifting issues going into 1st and reverse on occasion. My mechanic showed me the worn parts and said they need replacement. Not sure what they are called, and want to know if they are available new.
Big thanks to Bruce Stone; he brought the parts and saved the day ! Lastly, why did they wear out ? Attached image(s) |
type47 |
Feb 3 2014, 02:58 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Not sure what you're showing, you have 3 pix. It would seem to me the first pic is of a tube or the ball the shift fork pivots on. The second is the fork which should have a white plastic cup/bushing/socket/? in the hole for the pivot ball, the third is the shift fork. What are you asking about?
There is a link to the 914 PET in my signature. These parts are shown in an exploded diagram in 301-10 along with part numbers. |
Mblizzard |
Feb 3 2014, 03:04 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Not sure what you're showing, you have 3 pix. It would seem to me the first pic is of a tube or the ball the shift fork pivots on. The second is the fork which should have a white plastic cup/bushing/socket/? in the hole for the pivot ball, the third is the shift fork. What are you asking about? There is a link to the 914 PET in my signature. These parts are shown in an exploded diagram in 301-10 along with part numbers. Took one apart that was missing the white plastic cup and there was not much left of the ball. This ball looks better than the one that was put together with out the cup so I guess it is the plastic cup? |
jim_hoyland |
Feb 3 2014, 03:13 PM
The plastic cup was missing; I have a replacement. The cups are easy to find
76-914 |
Feb 3 2014, 03:32 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
That's why it's worn, Jim. No cup washer. Should feel much smoother now.
jim_hoyland |
Feb 3 2014, 04:39 PM
Dave_Darling |
Feb 3 2014, 04:49 PM
Usually it should be replaced every time you replace the clutch. Mostly because it's a pain to tear everything apart again later just to replace a freakin' 75-cent bushing.
--DD |
r_towle |
Feb 3 2014, 11:14 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It is suggested that you replace all your plastic shifting parts at every 40 year scheduled service period.
You are all set for a while now. |
jim_hoyland |
Feb 4 2014, 01:02 PM
New info: I found the clutch release fork is NLA; but found a number of them on eBay for prices ranging from $35 -$85
The round gizmo seems to be available . Couldn't find any throw out bearing shafts. Good news is Bruce has the parts and we are back in business |
rhodyguy |
Feb 5 2014, 07:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
jim, you'll a new release lever retaining clip too. tiny, they usually are cracked. haynes p70 fig 3.1.
jim_hoyland |
Feb 5 2014, 07:43 AM
jim, you'll a new release lever retaining clip too. tiny, they usually are cracked. haynes p70 fig 3.1. Right: I had ordered the retaining clip along with other small parts. The granny's back in the car and it feels good. The occasional grinding into 1st and reverse has stopped. I ended up installing new flywheel, new PP, new clutch, new TO bearing, and replaced the clutch release fork. Fortunately, I had accumulated all the major parts over the years at swap meets and sales. I have a good flywheel that I'll put up for sale; just needs resurfacing |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:34 AM |
