| Dredwin |
Feb 10 2014, 09:27 PM
Member ![]() ![]() Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains
I haven't seen this car in person but the body has some rust. The "hell hole" has been repaired. But I haven't done body work before. I'm a decent mechanic but have never done body work. (although I have drywalled the basement).
Looking over the forum, I know there are other areas to look for rust, but how difficult is this to repair? Thanks for any help you can give Attached image(s)
| partwerks |
Feb 10 2014, 09:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I have a small rust spot on the passenger side also. The only rust I have on mine, but will just have a body shop do it.
| Ferg |
Feb 10 2014, 09:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
Based just on those two pics, if u can't weld find another car
| Mike Bellis |
Feb 10 2014, 10:18 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I've seen better cars that were free... (IMG:style_emoticons/default/sad.gif)
| KELTY360 |
Feb 10 2014, 11:36 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,185 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
It's an iceberg.
| ConeDodger |
Feb 11 2014, 12:21 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Keep looking... (IMG:style_emoticons/default/sad.gif)
| Dredwin |
Feb 11 2014, 12:23 AM
| somd914 |
Feb 11 2014, 04:56 AM
Member ![]() ![]() ![]() Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Looks like you have rust at the lower end of the door jamb also, I would suspect the other sail panel is bad also, and there's likely a whole lot of rust hiding elsewhere.
So if it your not afraid of stuff like this, then go for it, but otherwise plenty of decent cars to be had if you look around for a while. ![]() |
| CptTripps |
Feb 11 2014, 05:01 AM
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest |
Yeah...let someone else "save" that one.
| Chris H. |
Feb 11 2014, 07:24 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Yep this is the clincher right here...
It's not really "natural" for rust to form there. It came from the inside out. See how its lumpy under the vinyl? That's more rust bubbles. Some people can fix that easily but it can be very frustrating for a first-time build. You can expect it to be much worse under there. |
| KELTY360 |
Feb 11 2014, 07:29 AM
It's an iceberg. Or is this the Titanic? It was listed as $2500 but they completely rebuilt the engine. I have my eye on another car. Thanks for the advice (although I am interested in learning to weld, but don't want to practice on the body. No, you'd be the Titanic if you hit on this one. There is so much rust under the surface that the car is being held together by habit. |
| worn |
Feb 11 2014, 09:49 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
It's an iceberg. Or is this the Titanic? It was listed as $2500 but they completely rebuilt the engine. I have my eye on another car. Thanks for the advice (although I am interested in learning to weld, but don't want to practice on the body. No, you'd be the Titanic if you hit on this one. There is so much rust under the surface that the car is being held together by habit. I once visited the castle where the Pythons yelled "run away, run away!" This is the advice you are getting and it is good. But how many among them (the advisors, not Monty Python)did not gain their wisdom by diving into a car like that? I know I have a whole set of tools and lots and lots of scrap iron that I would not have if I hadn't decide to save a TR6 and an MGB that should have been scrap. The MGB floors were swept up in little chunklets and placed in grocery bags for the trash. Doing the same on a teener. I hope they land in good hands but at least they didn't hit the ship to China as a crushed cube on my watch. This is what you would be getting into. Still if you are car shopping, you can surely do better. Or buy it for the drive train and find another. Problem is there are a lot more rusted cars with solid motors than the other way round. |
| 76-914 |
Feb 11 2014, 09:58 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
This would be a much better start with a little rust repair in the trunk. Not a difficult fix and this car is priced right! http://www.914world.com/bbs2/index.php?showtopic=230106
| ClayPerrine |
Feb 11 2014, 10:24 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Yep this is the clincher right here... It's not really "natural" for rust to form there. It came from the inside out. See how its lumpy under the vinyl? That's more rust bubbles. Some people can fix that easily but it can be very frustrating for a first-time build. You can expect it to be much worse under there. Actually it is very common for a 914 to rust there. Porsche/VW put foam in the corners to prevent rust. Well, it did just the opposite. The foam sucked up water, and held it against the mild steel sheet metal, and rust resulted. Use carburetor cleaner to remove the foam. Cut out the rusted area, and weld in a new section. The most common places that cause a 914 to be terminal is under the battery tray, the hell hole and the suspension console. |
| Chris H. |
Feb 11 2014, 10:40 AM
Oh I'm aware it's common for a 914 to rust there. Seen it dozens of times here in the midwest since the salted roads in the winter accelerated the problem. That's the first spot I check when looking at a car in Chicago since flippers had a tendency to slap a chunk of bondo in there.
My point was that if you look at the rust not knowing much about 914's it's not a very natural spot for rust to accumulate since it's sloped in a way that would not trap water. It's rusty because it's rusting from the inside out. |
| 914werke |
Feb 11 2014, 11:04 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,606 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
BTW that's not so much "foam" like the material shot into the deck/truck lids, as it is Seam sealer.
Tough stuff and a tricky area to remove from since its surrounds/envelops the fresh air vent tubes which *WILL* be rotted as well. |
| worn |
Feb 11 2014, 11:21 AM
[/quote] No, you'd be the Titanic if you hit on this one. There is so much rust under the surface that the car is being held together by habit. [/quote] I should have also mentioned that you can count on NOT driving around in a zippy sports car when it is up on jack stands for the 4-5 years it generally takes for amateur repairs of any magnitude. (IMG:style_emoticons/default/chair.gif) |
| Dredwin |
Feb 11 2014, 11:29 AM
Thanks for the advice. The guy says is some rust on the longitudinals. I am looking at another car and hoping it isn't quite the rust bucket this one appears to be. While I would love this car, it would be a love/hate relationship and a money pit. Not that it wouldn't be worth it, since I've always wanted a 914, but probably wouldn't love it enough to get a divorce since my wife would kill me for buying such a problematic car.
| ClayPerrine |
Feb 11 2014, 01:09 PM
One suggestion... show up with an ice pick and poke anything that even looks suspicious. Especially the longs and the suspension points. But check the floor pans and the firewall bottom too.
| 914werke |
Feb 11 2014, 01:33 PM
Best option would be to remove the rockers. But the best you can hope for is the owner will allow them to be opened at the bottom so you can peer up & determine how bad it really is. (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:07 PM |
