That piece in front of the headlight..., is no longer there. |
john77 |
Mar 13 2014, 08:25 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Did my first autocross at the weekend. Had a great day but got home to find part of my car missing. The two rubber grommets to the right are still stuck in the body but there isn't one to the left into the fender, so I'm guessing that's the culprit.
Emailed the organizers and if it was found and handed in I may yet be able to pick it up next month. If not, it's now living somewhere on the 405 (IMG:style_emoticons/default/smile.gif) Are these readily available? The only pita is that I'm going to have to try to match the paint. Thanks John |
cwpeden |
Mar 13 2014, 08:33 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Did you look under the light, in the bucket?
r_towle |
Mar 13 2014, 08:38 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have them, but it's probably way easier for you to call EASY up in San Francisco area, or HPH up there also...both have lots of 914 parts....
Good part is those rarely rust, so they are in many stash piles. Look hard and I bet you can find a silver one....closer than a red one... Rich |
john77 |
Mar 13 2014, 08:40 PM
Did you look under the light, in the bucket? Yep, although only just now when I took the photo (IMG:style_emoticons/default/smile.gif) |
john77 |
Mar 13 2014, 08:41 PM
I have them, but it's probably way easier for you to call EASY up in San Francisco area, or HPH up there also...both have lots of 914 parts.... Good part is those rarely rust, so they are in many stash piles. Look hard and I bet you can find a silver one....closer than a red one... Rich Thanks Rich, will do. |
sbsix |
Mar 13 2014, 10:19 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 451 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
EASY is in Emoryville, CA near Oakland and has them, but their stock of old 914 parts is getting pretty low now. Jim and John run a great place and it's always fun to poke around searching for parts. Give them a call.
Lo-Fi Version | Time is now: 1st June 2024 - 06:51 PM |
