lennyhope |
Member ![]() ![]() Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England ![]() ![]() |
Hi folks.
I am trying to fit a new head temp sensor to my 1.7. I cannot find a way to get a new one in place! Any suggestions as to tricks as to how to do it? I am getting desperate now!! (IMG:style_emoticons/default/sad.gif) |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Supposedly you can get it in without removing any FI parts.
You need a deep socket and you can tuck the wire inside the socket. Otherwise, use a cheap socket and cut a slot in it for the wire to stick out. |
luskesq |
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California ![]() |
I took a cheap 3/8" extension (2"), cut a slot up one of the corners on the male end, large enough for the wire to fit into (it is a small wire so it isn't a big slot. I used a dremel to cut the slot but I suppose you could even grind one of the corners. Put the sensor in your socket and position the wire in the appropriate corner where your extension will go in and install (with some anti-seize). The slot really doesn't appreciably weaken the extension for other use but I used a cheapie HF one.
Might also want to use a drop of crazy glue on the crush washer to keep it from falling off the sensor when installing. Good luck, Keith Good luck. |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Did this last fall. Found it to be a PITA (IMG:style_emoticons/default/mad.gif) Like about stated I took a 13mm deep socket and cut a slot in it for the wire. I used a little grease to hold the washer on the sensor. The socket with a swivel head on it and was able to get it in.
In the past I found it just easier to pull the intake runners to do it. I didn't need to remove them completely just held them up enough to be out of the way. (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,324 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Supposedly you can get it in without removing any FI parts. You need a deep socket and you can tuck the wire inside the socket. Otherwise, use a cheap socket and cut a slot in it for the wire to stick out. I bought a deep socket for $5. Tucked the wire inside. Used a bit of painters tape to hold everything secure. Took 5 minutes. |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
If you don't want to cut up a socket, you can feed the wire through the socket and tighten it with a screw driver. A large flat tipped screw driver will fit where the the socket attaches to the ratchet. Vise grips on the screw driver and your good to go!
mepstein |
Supposedly you can get it in without removing any FI parts. You need a deep socket and you can tuck the wire inside the socket. Otherwise, use a cheap socket and cut a slot in it for the wire to stick out. I bought a deep socket for $5. Tucked the wire inside. Used a bit of painters tape to hold everything secure. Took 5 minutes. Honestly, a deep socket from the local hardware store will work great. no cutting or vise grips required. they are sold seperate for ~$5. Since the wire gets tucked inside, there is no way to damage t against the engine tin. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Slightly OT, but my 1.7 does not have any heat temp sensor, not sure if it's only to feed into the FI system, or if it goes to a dash gage measuring heat temp, sorry to be so un-informed, help me out here.
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Slightly OT, but my 1.7 does not have any heat temp sensor, not sure if it's only to feed into the FI system, or if it goes to a dash gage measuring heat temp, sorry to be so un-informed, help me out here. there are 2 different head temp sensors one screws into the block for fuel injection the other on a spark plug for a gauge if you have (or want) a running fuel injection then you have a head temp sensor if you use carbs, then its not needed for the F.I. brant |
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
It's a sensor for the fuel injection system.
Not an oil temp sensor. You'll seen a fine wire coming out of a hole in the engine tin right above the #3 cylinder. |
lennyhope |
Managed it with finger tips and long reach socket 13mm
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Lo-Fi Version | Time is now: 16th June 2024 - 12:35 PM |
