OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
So I bought a steering column with the ignition switch and associated wiring and turn signal. I went to install it on my 71 and the plug is different. My car's plug has a center rib that runs between the individual plugs but my "new" column and plug do not. It sucks because I spent money keying the switch as it did not come with a key.
I was too pissed at the time to get a photo (IMG:style_emoticons/default/dry.gif) Comments? So I bought another column that I know is from a 1971 car, it doesn't f!#king fit either! My car was built in 07/1971.... Column plug on the left, car on the right. How can I make this work? Can somebody sell me what I need? ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
70 & 71 have a unique steering column and ignition. I might have the ignition plug you need in a parts car. You would have to graft it into your harness. PM me if you want it.
OU8AVW |
Let me see if I can find a column. Thanks
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,198 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
70,71 column were sourced from the VW Type 3 parts . When the 72 came along with the built in wiper switch they were sourced from the VW Type 1 Bug.
OU8AVW |
Please see edit in first post (IMG:style_emoticons/default/blink.gif)
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,978 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The best idea would be to keep looking for a 1971 steering column, that has the 14pin connector. The 12pin is a 1970 column, I tmay have come from a 1971 car, but it was not original to it. The 1971 chassis harness has a 13th wire in it that the 1970 does not have, and uses the 14pin connector with one empty cavity.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
You'll want to be sure the replacement column bolts in, as well. That changed, too, but I'm not sure when.
The Cap'n |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,309 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Mike Why not just change the connector?
PM me. Attached image(s) ![]() ![]() |
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
Mike Why not just change the connector? PM me. I worked on my som's 70 today with the same issue . I attempted to change the connector but 3 or 4 of the wire colors didn't match. I manage to make it work for the most part, after an hour of testing. I still have to do some more testing in the morning. |
JeffBowlsby |
Brad Mayeur has an NOS 1971 column on ebay right now...or contact him directly.
http://www.ebay.com/itm/Porsche-914-1971-S...4de&vxp=mtr |
hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 628 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
I have a 70. bought one that was for 72. grrrrr Call Easy Porsche Parts in Emeryville, cali. and see if they have one.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Brad Mayeur has an NOS 1971 column on ebay right now...or contact him directly. http://www.ebay.com/itm/Porsche-914-1971-S...4de&vxp=mtr (IMG:style_emoticons/default/agree.gif) buy the one on ebay. sell the others. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Porsche sells both the male and female 14 pin connector shells brand new. Just buy two of them and replace the shells.
OU8AVW |
JeffBowlsby |
Someone had contacted me recently about this...I did a study with the limited information I have. The major problem is that there is no 1970 chassis harness schematic available and I have not had an opportunity to completely wring out a 1970 harness to know what each circuit it. Based on wire color only:
Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 19th July 2025 - 06:55 AM |
