Single turn signal indicator to dual, On the tach |
Qarl |
Mar 23 2014, 09:37 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Just doing some pre-planning here.
My '75 had the single turn signal indicator. The -6 Tach I had converted has the left and right turn signal indicators. Any suggestions on where to tap into near the fuse panel to get a true left and right turn signal indicator. (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1395589045.1.png) (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1395589047.2.png) |
timothy_nd28 |
Mar 23 2014, 09:41 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
The hazard switch has all the good stuff to tie into. I found this thread very helpful
http://www.914world.com/bbs2/index.php?sho...;hl=turn+signal |
Bartlett 914 |
Mar 23 2014, 09:42 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I did mine years ago. Car is now cut up and gone. IIRC, there was an additional connection at the turn signal relay. I ran the wire (s) from there
Spoke |
Mar 23 2014, 10:54 AM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I went the simple way:
Ground one wire from each indicator. Tap L and R front turnsignal wires from the hazard switch for each indicator. |
Qarl |
Mar 23 2014, 12:06 PM
I went the simple way: Ground one wire from each indicator. Tap L and R front turnsignal wires from the hazard switch for each indicator. Thanks. It's interesting that the signal (voltage) would go all the way back to the switch (versus the relay), when the turn signals are activated from the turn signal stalk. I appreciate the info. |
larryM |
Mar 23 2014, 12:16 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
horrors - you might lose originality points if you do this - so who cares? |
Qarl |
Mar 23 2014, 02:46 PM
Spoke |
Mar 23 2014, 04:12 PM
Here's a schematic view of the turnsignal wiring. If you follow the top connection of each indicator lamp you will see it leads to the hazard switch and the turnsignal stalk.
Thus when retrofitting a 74+ with dual indicators one only needs to find the wires on either item. It is much easier to find the wire on the hazard switch than the turnsignal stalk. Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 08:04 AM |
