| mskala |
Mar 23 2014, 12:39 PM
R ![]() ![]() ![]() Group: Members Posts: 1,942 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
Al rear 914-6 calipers from Eric. Much lighter than stock.
![]() However, he neglected to inform that they do not use the one 'large' pin for the top hole, the holes are all the same. I couldn't use 2 of my original pins, so decided to waste some time making an aluminum set; save more weight! ![]() |
| scotty b |
Mar 23 2014, 12:46 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
He's not really much of a " detail " guy (IMG:style_emoticons/default/mellow.gif)
Nice work (IMG:style_emoticons/default/first.gif) |
| sixnotfour |
Mar 23 2014, 11:02 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,199 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
No rear brake pads come with the enlarged holes anymore..OG they had a taper ground on them thus making the enlarged hole necessary.... show me replacement pads with this ....,., I have some, if you want to be anal
| steuspeed |
Mar 23 2014, 11:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I had to hog out my porterfield pad holes to get them to work on my stock calipers.
(IMG:style_emoticons/default/sawzall-smiley.gif) |
| mskala |
Mar 24 2014, 06:03 AM
No rear brake pads come with the enlarged holes anymore..OG they had a taper ground on them thus making the enlarged hole necessary.... show me replacement pads with this ....,., I have some, if you want to be anal I know about pads, in fact I now have an extra new set that I drilled the large hole in. The Aluminum calipers have been cast with 2 small holes, unlike the real 914 rears. So, good that it isn't necessary to drill pads any more, but bad at first that the existing pins won't work. |
| ThePaintedMan |
Mar 24 2014, 07:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Cool! How do you think those pins will hold up long term with the steel pads riding on them? Probably one of those things you just replace with each pad change?
Lo-Fi Version | Time is now: 14th April 2026 - 05:24 PM |
