| madmax914 |
Mar 24 2014, 11:56 AM
Member ![]() ![]() Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
I am weighing my fuel options on a 1.8L 2056 motor I'm building. Carbs seem to be the choice on builds like these but I was looking at staying factory FI with a Mega squirt conversion. My question is has anyone done the Mega squirt on an L-jet tronics? And second what's going to give me better throttle response?
Your opinions are greatly appreciated! Thanks |
| vw505 |
Mar 24 2014, 12:12 PM
Member ![]() ![]() Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
I have 44 webbers with 32mm vents on my 2056, I've only driven a few time since installing the new motor but I am very happy ith how it runs.
| type47 |
Mar 24 2014, 01:56 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
... a 1.8L 2056 ... at staying factory FI with a Mega squirt conversion. ...the Mega squirt on an L-jet tronics? ... Please re-explain your question. To me, there are alot of conflicting facts. Don't mean to offend but this is how I read it. 1) a 2056 is a displacement increase of an engine. A displacement increase using a 2L 71mm stroke crankshaft and 96mm pistons makes a 2056 cc out of "any" case. A 1911 is using 96mm pistons with a 66mm crankshaft that is common to 1.7 and 1.8L's using "any" case. 2) Mega squirt is a digital fuel injection system that would replace the L-Jet (or D-Jet) factory system. Microsquirt, SDS, Haltech and many more are modern digital fuel injection systems. 3) don't know about the throttle response but I bet the best designed one with matched parts will yield the highest hp and torque for best throttle response. |
| Mark Henry |
Mar 24 2014, 03:59 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I think he's asking if you can keep the stock fuel induction system and just use MegaSquirt as the brain. That's what my answer below is based on.
Yes and no. (IMG:style_emoticons/default/biggrin.gif) You can but you would need to get rid of the flapper, add a TPS from a 90's up car, find a place to take a vac signal from and the L-jet injectors suck for performance. There's also a couple of sensors to mount. The 2.0 D-jet (or some other) injectors would work better, the 2.0 D-jet pressure reg is better as well and the L-jet TB is a bit on the small side. So yes it can be made to work...but....not a simple swap. Then there is also all the work and wiring for installing the MS. BTW the 2.0 D-jet TB and plenum would be a better choice but that needs some (IMG:style_emoticons/default/smash.gif) as well. |
| madmax914 |
Mar 24 2014, 04:09 PM
I am running a 2.0L 71mm crank and 96mm cylinders. Really what I wanted to know is if I should dump the L-Jet for a D-jet. I was under the impression that the Megasquirt FI is a computer brain that works in conjunction with the stock FI system. I think Mark Henry answered the question.
Thanks guys, |
| Mblizzard |
Mar 24 2014, 05:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am running a 2.0L 71mm crank and 96mm cylinders. Really what I wanted to know is if I should dump the L-Jet for a D-jet. I was under the impression that the Megasquirt FI is a computer brain that works in conjunction with the stock FI system. I think Mark Henry answered the question. Thanks guys, I am running the D-Jet with some slightly higher flow rate injectors and a slight increase in fuel pressure and I am pretty happy with the way it runs. |
| messix |
Mar 24 2014, 05:45 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
what cam are you using?
| madmax914 |
Mar 25 2014, 12:00 PM
| jcd914 |
Mar 25 2014, 07:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If it was/is a running 1.8L with functioning L-jet, the simple solution is to cam it mildy and continue to use the L-jet.
L-jet can easily handle a 2056. The simple solution is often the best solution. Jim |
| JamesM |
Mar 25 2014, 10:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,271 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
You could do it but the d-jet conversion to megasquirt is a little easier/better given that you can use pretty much all stock parts/sensors (and wiring if you really know what you are doing)
Fuel injectors, intake runners, plenum, throttle body, AAR, and head temp sensor are all you would really re-use from L-jet. You can leave the air flow meter in place unused if you like in order to use the stock airbox, or ditch it to remove the obstruction and fab up your own air filter. The other thing that L-jet lacks (that d-jet has) is an intake air temp sensor, so you will need to fab up a place to install one of those as well along with all the wiring. TPS is optional but if you want one that will need to be custom as well. 2L injectors are HUGE, good for well over 200HP, so huge that on the earlier low res versions of Megasquirt it was impossible to get a decent idle with them. 1.7s would be a good fit, 1.8s might be getting to small. Best bet might be the later Vanagon injectors as I believe they were high impedance (no resistors needed),around 24lb/hr, have a barb fitting and the better connector (d-jet connectors sort of suck). I have heard L-jet does work fine with some 2056 builds if the cam is not to crazy, so if your L-jet system is good you may just want to stay with that for cost/ease of install, though I personally always go Megasquirt. |
Lo-Fi Version | Time is now: 12th July 2026 - 06:29 PM |
