Back Pad Removal, how does the engine lid release come off? |
7TPorsh |
Mar 26 2014, 02:54 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I want to take off my backpad to put on some sound deadner but i can't remember how I took it off the last time.
I can't seem to get the engine lid release off. Do I loosen the cable on the engine side? It's not unscrewing, the whole thing turns then snaps back... |
JawjaPorsche |
Mar 26 2014, 03:12 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I want to take off my backpad to put on some sound deadner but i can't remember how I took it off the last time. I can't seem to get the engine lid release off. Do I loosen the cable on the engine side? It's not unscrewing, the whole thing turns then snaps back... Put pliers on shaft to hold it, then twist cap off. Take seats out. Remove screws from cover. Pad is removed by pushing down. |
7TPorsh |
Mar 26 2014, 03:21 PM
'Put pliers on shaft to hold it, then twist cap off."
On the engine side? or pull on the handle from the inside? does the handle unscrew and the cable comes out the back side?'P |
vw505 |
Mar 26 2014, 03:22 PM
Member Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
From the inside
TheCabinetmaker |
Mar 26 2014, 03:30 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Pull the handle and release the lid. Then grab the cable behind the knob with needle nose and unscrew the knob. Then use the needle nose to remove the escution.
orthobiz |
Mar 26 2014, 07:41 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I'm so glad you asked this. Saved me from making another "how do I..." thread!
Paul |
DRPHIL914 |
Mar 27 2014, 07:49 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Pull the handle and release the lid. Then grab the cable behind the knob with needle nose and unscrew the knob. Then use the needle nose to remove the escution. -- then remember when you pull the back pad out that you pull the bottom out away then pull it down and the clips at the top should just slide out. i didnt remove my seats, but had them as far forward as they go, but withstock seats it is much easier to justpull them out for sure. |
orthobiz |
Mar 29 2014, 09:28 PM
luskesq |
Mar 29 2014, 09:38 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
It sunscrews
Keith |
Dave_Darling |
Mar 30 2014, 01:09 AM
The escutcheon unscrews. So do the four screws through the back pad into the firewall.
Pull the bottom of the pad forward, and slide the top of the pad down. Don't forget to unhook the interior light. The power wire is always hot, so tape it up so it can't short to anything. Or just disconnect the battery ground before you start. --DD |
7TPorsh |
Mar 30 2014, 10:39 AM
go it, thanks.
I didn't realize there is a insulation pad under there |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:24 PM |
