| porbmw |
Mar 30 2014, 10:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None
I am going to be needing at least 2 or 3 of these...just in case
Any recommendations..... |
| Big Len |
Mar 30 2014, 10:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,781 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Me too. (IMG:style_emoticons/default/popcorn[1].gif)
| Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
A 5lb BC is all you need.
| brant |
Mar 30 2014, 10:43 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,183 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I think the BC is corrosive to different metals?
haven't ever used one personally... of course if your car is burning down, corrosion may not be the biggest concern. I'd just hate to put out a tiny fire, like wiring under the dash... and then find out that all of the connections and wiring is trashed due to corrosion but halon or halotron was sold as an automotive application and now the new foam extinguishers are considered safer (inhalation) and more environmentally friendly... (although I believe they have to be tested and certified every other year which is a huge trade off) don't breath halon it only takes a second a friend's teener caught on fire in staging he hit the system button, and passed out before he could get out of the car another friend drug him out the window and got small burns on his hand while doing it.... exit the car with halon.. hell exit the car with any fire. (that teener burned to the ground in staging) |
| Mike Bellis |
Mar 30 2014, 10:58 AM
Most racing sanctioning bodies want a BC or Halon system. Halon is now illegal to produce due to greenhouse effects. So the prices to refill will only go up. I have both a BC and an AFFF (Fire Foam) system. Most racing sanctioning bodies have not fully accepted the AFFF systems but I don't care. My BC keeps me legal. My AFFF will keep the fire at bay. The AFFF system I use can be refilled at the track if needed. http://augustamotorsports.biz/firecharger-...guisher-system/ (IMG:http://www.914world.com/bbs2/uploads_offsite/i9.ebayimg.com-10496-1396198690.1.JPG) |
| MMW |
Mar 30 2014, 11:07 AM
Member ![]() ![]() Group: Members Posts: 152 Joined: 6-October 13 From: Northern NJ Member No.: 16,477 Region Association: North East States |
I have halotron in my car. I would only use a bc as a last resort. I was told that the chemicals in bc start corroding immediately. It is difficult to clean up & if sucked into a running engine will pretty much ruin it. Halotron is a gas with no residue. The cost is more than powders but if it saves the car & doesn't due any collateral damage it is worth it.
FYI if you have an engine fire spray through the vents. Do not open the engine lid as it will increase the fire due to the added oxygen available. Attached image(s)
| stugray |
Mar 30 2014, 11:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have that system. Never had to use it yet and hopefully never have to. Note: Those come in two sizes. The smaller supports two nozzles and the large three. Decide what you need before ordering. |
| orthobiz |
Mar 30 2014, 12:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,765 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
I have some handheld Halon extinguishers, but am only ready to treat small fires obviously. Thought about the Halotron and I think it's a good modern way to go but per unit extinguisher size, it's less effective than Halon. Maybe think doubling the requirement for an individual application? Some is definitely better than none!
Paul |
| 1970 Neun vierzehn |
Mar 30 2014, 06:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
I've got this at the small, local general/civil aviation airport nearby. They have told me that there is no problem with its use in their civil aviation application.
| Porsche930dude |
Mar 30 2014, 06:34 PM
Member ![]() ![]() Group: Members Posts: 399 Joined: 25-November 11 From: NY Member No.: 13,819 Region Association: None |
one reason i ran my fuel lines into the top of the tank. those bottom feeders just beg for disaster
| pvollma |
Mar 30 2014, 06:46 PM
Member ![]() ![]() Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region
Lo-Fi Version | Time is now: 1st May 2026 - 03:31 AM |
