Directional Switch Change out., How hard or a job is it. |
wndsnd |
Apr 1 2014, 06:53 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
My directional switch will not reset and I can not hear the relay over the engine and I can not see the indicators behind the wheel. I am constantly finding them blinking away and its making me crazy.
Since I know I hate working on anything dash related, I thought I would ask what kind of a project is this? Thanks John |
bdstone914 |
Apr 1 2014, 07:08 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
My directional switch will not reset and I can not hear the relay over the engine and I can not see the indicators behind the wheel. I am constantly finding them blinking away and its making me crazy. Since I know I hate working on anything dash related, I thought I would ask what kind of a project is this? Thanks John The flasher relay is accessed by dropping the fuse panel after removing the two screws. The relay is clipped to the rear portion of the fuse panel. The turn signal switch requires removing the steering wheel. I think you may have to drop the lower dash to get to the socket at the bottom. |
wndsnd |
Apr 1 2014, 07:19 PM
Bruce
I think my relay is in the dash on the sill plate. Getting to it is almost impossible from underneath. Probably the best way is through the instrument panel. My problem is with the column lever. That's what I have to replace. John |
TheCabinetmaker |
Apr 1 2014, 07:31 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Pull the steering wheel (easy). You can then see if the return tabs are intact. The 4 small screws around the perimiter will prohibit cancellation if too tight.
r_towle |
Apr 1 2014, 07:37 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pull the steering wheel (easy). You can then see if the return tabs are intact. The 4 small screws around the perimiter will prohibit cancellation if too tight. (IMG:style_emoticons/default/agree.gif) There are two little plastic things one on each side at 9and 3 also Rich |
wndsnd |
Apr 1 2014, 07:45 PM
TheCabinetmaker |
Apr 1 2014, 09:15 PM
If it does need to be replaced, just remove the 4 screws and gently wiggle it out. You will have to remove the knee pad to plug the new one in. It's a 2 on a one to ten scale.
Lo-Fi Version | Time is now: 10th June 2024 - 09:38 PM |
