> rear shocks
fduval
post Apr 5 2014, 02:06 PM
Hi , I am new to the 914 ownership, just bought the car from member KADUKU !
The rear end of the car is kind of very soft, I guess
the rear shocks need to be replaced, what do you guys recommend for street use .
The car is a 1973 with a 2 liter engine.
Thanks
Replies(1 - 19)
smarens
post Apr 5 2014, 02:11 PM
I'm in the same boat, are you looking at doing just shocks or springs also? I've see a lot about not using KYB, good things about Bilstein and upgrading to 100lb springs over stock 90lb, I'm thinking of doing mine myself but need to get a spring compressor, sorry to not have expert advice but that is just what I have read so far
fduval
post Apr 5 2014, 02:19 PM
QUOTE(smarens @ Apr 5 2014, 12:11 PM) *
I guess I should do both ! 100 lbs spring seems to be a good improvement
Johny Blackstain
post Apr 5 2014, 02:31 PM
The upgrade to 100lb springs is common & as for the shocks I'd go with Bilstein. I prefer them over either Boge & Koni for daily use, but that's just me.
fduval
post Apr 5 2014, 02:35 PM
QUOTE(Johny Blackstain @ Apr 5 2014, 12:31 PM) *
Thanks for the welcome Johny
post Apr 5 2014, 02:37 PM
914-6 GT in waiting
I did it myself with boge's and 100 springs and dropped by my local mechanic and he compressed the springs for no charge. Took him 2 minutes.
stugray
post Apr 5 2014, 02:43 PM
If you want a really good setup, get a set of adjustable perches, springs and shock from ground control.
Based on your application they will calculate exactly what you need.
I also have a set of stock "barely used" springs, and a set of new weltmeister 180lb springs that I dont need.
I even have a decent set of Koni adjustable shocks, but messed up the threads at the top of one of them.
carr914
post Apr 5 2014, 04:20 PM
Racer from Birth
Koni - Koni has their Yearly Sale going on right now
barefoot
post Apr 5 2014, 05:31 PM
Lots of auto parts stores will lend spring compressors, that's what i did
914_teener
post Apr 5 2014, 05:36 PM
QUOTE(mepstein @ Apr 5 2014, 01:37 PM) *
This is what I did. Just make sure your control arm bushings aren't shot. Otherwise all for not....... doesn't matter what shock you use.
saigon71
post Apr 6 2014, 08:36 AM
I am very happy with Billsteins for my street/DD car.
I stuck with my stock springs. I highly recommend replacing your springs "while you are in there" as I have noticed some sag in the rear of the car. I'm going to pick up a new set of springs to be installed next time I drop the trailing arms.
For a street car I think 80-100 lb springs with a good set of shocks is a nice setup.
carr914
post Apr 6 2014, 10:25 AM
Racer from Birth
QUOTE(smarens @ Apr 5 2014, 04:11 PM) *
QUOTE(barefoot @ Apr 5 2014, 07:31 PM) *
You don't need Spring Compressors!
Take off bolts in Trunk, Jack up the Rear of the car, the Springs & Shocks will drop. Un-do bottom Shock Bolt, take off. Reverse the proceedure & you are done!
post Apr 6 2014, 11:11 AM
914-6 GT in waiting
QUOTE(carr914 @ Apr 6 2014, 12:25 PM) *
I needed them compressed to get the bolt back on the shock with the new springs. I could get it close but after a half hour of trying I drove the 2 miles to the shop and got it done.
carr914
post Apr 6 2014, 03:42 PM
Racer from Birth
QUOTE(mepstein @ Apr 6 2014, 01:11 PM) *
If you had sat in the Trunk, your weight would have compressed the Springs and you would have gotten the nut on
injunmort
post Apr 6 2014, 05:46 PM
I did this today, bilsteins to replace kyb, s and 100lbs. springs. set clip second to top position on shock body and assemble, no spring compressor needed. no spring compressor needed to disassemble the kyb's either.
wndsnd
post Apr 6 2014, 08:10 PM
You wanted a horse, but got a goat. Nobody wants a goat....
Are you guys replacing the bump stops and if so where did you get them?
John
Paragon
post Apr 7 2014, 05:06 AM
QUOTE(wndsnd @ Apr 6 2014, 06:10 PM) *
John
The Koni Competition bump rubbers may be worth considering.
injunmort
post Apr 7 2014, 06:05 AM
I reused the bumpstops as they were ok
Mr Pharmacist
post Apr 7 2014, 02:40 PM
Region Association: England
QUOTE(carr914 @ Apr 6 2014, 10:42 PM) *
Thanks for that handy hint - tried it earlier and worked a treat - much easier than using spring compressors!!
Any handy hints for changing the front inserts? (sorry for the hijack but did a quick search and couldnt seem to find a post on how to go about this)
Thanks
Paragon
post Apr 7 2014, 04:14 PM
Thanks
Easy. We wrote this years ago...kind of generic but I think you'll get the idea:
https://www.paragon-products.com/kb_results.asp?ID=1
- Lo-Fi Version Time is now: 6th July 2025 - 02:06 PM
