> GC engine code '75-'76 2.0 questions, Can I make it into a Ga or GB engine?
buck toenges
post Apr 8 2014, 08:08 PM
I see that the Ga engines put out 95hp with a 7.6 to 1 cr. The GC has the same cr but less horse power. I assume it is due to emissions crap. The Gb has a 100hp and a 8.0 to 1 cr. They all used d-jet. Can I get my GC engine to be like a GB engine and how do I do it?
Replies(1 - 4)
SLITS
post Apr 8 2014, 09:25 PM
"This Utah shit is HARSH!"
1.) Back date to '73 - '74 exhaust system.
2.) Plug air injection holes.
You now have a '73 - '74 engine.
Bob L.
post Apr 8 2014, 09:33 PM
I believe the cases are all the same. Compression ratio, heads, exhaust & ECU tuning were changed. Even the 1.7 & 1.8 cases were the same as the 2.0. Just stamped with the appropriate code for hat it was built out to.
check the "914 Info" link at the top of every page.
If the case spec's out, make it into whatever you want.
Keep us posted.
poorsche914
post Apr 8 2014, 09:43 PM
T4 Supercharged
GB case designates the euro engine with higher compression for a bit more power. You can get euro P/C kits.
r_towle
post Apr 9 2014, 06:45 AM
Custom Member
QUOTE(SLITS @ Apr 8 2014, 11:25 PM) *
Basically
- Lo-Fi Version Time is now: 3rd July 2025 - 08:36 PM
