Surface rust in the tunnel |
vw505 |
Apr 17 2014, 08:56 AM
Member Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
What is the best way to clean up rust in the tunnel? I think in the past the brake line leaked and now there is a lot of surface rust in there.
CptTripps |
Apr 17 2014, 09:21 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
What is the best way to clean up rust in the tunnel? I think in the past the brake line leaked and now there is a lot of surface rust in there. If it truly is surface rust, scrape off what you can and use something like the Eastwood spray kit to seal it up. Without cutting the tunnel apart, you won't be able to get anything in there to scrape much of it away. |
hndyhrr |
Apr 17 2014, 09:28 AM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I scraped as much as i could and then used the vacuum cleaner with very small attachment to get 95 percent of it, then spread rust killer with paint brush attached to coat hanger to get in there. pita but it worked. |
vw505 |
Apr 17 2014, 09:35 AM
I knew tis was going to suck.
Socalandy |
Apr 17 2014, 09:53 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
What is the best way to clean up rust in the tunnel? I think in the past the brake line leaked and now there is a lot of surface rust in there. If it truly is surface rust, scrape off what you can and use something like the Eastwood spray kit to seal it up. Without cutting the tunnel apart, you won't be able to get anything in there to scrape much of it away. (IMG:style_emoticons/default/agree.gif) Just know that it flows freely threw seams so prep is key if you want to keep it contained to the tunnel Attached image(s) |
jacksun |
Apr 17 2014, 10:00 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
later
malcolm2 |
Apr 17 2014, 10:45 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) Just know that it flows freely threw seams so prep is key if you want to keep it contained to the tunnel 2nd (IMG:style_emoticons/default/agree.gif) I am still finding that green paint on stuff. My windshield, the door windows, under the dash, everywhere. And it is good to know that once dried, it will not come off very easily. I have been using a razor blade on the glass when I find it. Even that takes a few tries. The hose nozzle has 4 holes in it, 12, 3, 6 & 9 o'clock, so be prepared and cover up. Can't say how good it works, at least my rust did not eat thru after 12 months.... so far so good. Keep your eye on Eastman.com, they have sales quite often. |
McMark |
Apr 17 2014, 11:44 AM
Put carpet over it and don't think about it. (IMG:style_emoticons/default/biggrin.gif)
vw505 |
Apr 17 2014, 12:40 PM
I can't, I know its there. |
bembry |
Apr 25 2014, 07:27 PM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
I knew tis was going to suck. Post of the year! (IMG:style_emoticons/default/piratenanner.gif) I'm 100% with you on this---I just saw the inside of my tunnel, and was thinking the same thing. (IMG:style_emoticons/default/agree.gif) |
saigon71 |
Apr 27 2014, 06:29 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
This is what I did to clean areas like this:
1. Took an extension magnet and ran it through every opening to pull out any loose scale. 2. Jammed a wooden wire brush into a piece of copper pipe (pipe serves as an extension) and methodically worked the brush into as many areas as I could get. 3. Blast out with compressed air. 4. Repeat until you don't get any loose scale out of the area. 5. Tape all the openings of the tunnel closed except for one in the middle. I finished it off with two coats of Eastwoods Internal Frame Coating. I can't vouch for the product yet, but the extension wand works nicely to spread product in areas like this. Above all, yes...it does suck. Good luck! |
reharvey |
Apr 27 2014, 09:45 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
I scraped as much as i could and then used the vacuum cleaner with very small attachment to get 95 percent of it, then spread rust killer with paint brush attached to coat hanger to get in there. pita but it worked. (IMG:style_emoticons/default/agree.gif) Done the same thing many times and it always worked out. Ray |
vw505 |
Apr 28 2014, 07:54 PM
Just found that the brake line that was replaced is leaking. Guess that's were the rust came from.
Lo-Fi Version | Time is now: 6th June 2024 - 08:06 AM |
