Sound identifcation help needed, Car runs fine, but.... |
jim_hoyland |
Apr 26 2014, 03:31 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Car has been running fine. Recently, there is a sound coming from the right side; sounds similar to a brake pad rubbing against a rotor. Appears at cruzing speeds and goes away when the clutch is pressed in; it comes and goes.
Here's what already been done recently: new flywheel, PP, clutch, TO bearing and pilot bearing. Then Dr Evil looked at the tranny and replaced the pinion gears and 2nd gear dog teeth. The sound is not loud, barely notice it, but it's annoying. Anyone heard this sound ?; sounds just like the brake pad slightly rubbing on the rotor when adjusting. |
914_teener |
Apr 26 2014, 04:19 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
....hmmm....
I have a similar sound and I found out what it was a couple of days ago. When I did the rear suspension and replaced the trans mounts ... somehow I must have broke one of the motor mounts. When I hit it hard the motor shifts a little and when warm the back of the headers hit the heat shield and valance.....makes kind of a squeaking sounds like a brake pad indicator. Might have done something similiar? Check the back end Jim for something rubbing Jim. |
914_teener |
Apr 26 2014, 04:20 PM
.......oh nice avatar (IMG:style_emoticons/default/unsure.gif)
jim_hoyland |
Apr 26 2014, 04:39 PM
....hmmm.... I have a similar sound and I found out what it was a couple of days ago. When I did the rear suspension and replaced the trans mounts ... somehow I must have broke one of the motor mounts. When I hit it hard the motor shifts a little and when warm the back of the headers hit the heat shield and valance.....makes kind of a squeaking sounds like a brake pad indicator. Might have done something similiar? Check the back end Jim for something rubbing Jim. I'll take a look tomorrow; did your should go away when the clutch was depressed ? |
914_teener |
Apr 26 2014, 04:59 PM
....hmmm.... I have a similar sound and I found out what it was a couple of days ago. When I did the rear suspension and replaced the trans mounts ... somehow I must have broke one of the motor mounts. When I hit it hard the motor shifts a little and when warm the back of the headers hit the heat shield and valance.....makes kind of a squeaking sounds like a brake pad indicator. Might have done something similiar? Check the back end Jim for something rubbing Jim. I'll take a look tomorrow; did your should go away when the clutch was depressed ? No....clutch didn't affect it. Make sure everything is tight externally. |
r_towle |
Apr 26 2014, 05:20 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Dust shields?
76-914 |
Apr 26 2014, 05:31 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
There should be 50+ experts to look at it tomorrow, Jim. (IMG:style_emoticons/default/lol-2.gif)
Eric_Shea |
Apr 26 2014, 05:32 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Had a similar issue in my 911 when they installed the 915.
Went through two clutches and TO bearings. Finally looked at the install and they crammed the tranny against the body, shoved the rubber boot up the tunnel and basically left everything kinda 1/2 assed and undone. I believe the mount was even on upside down. Getting all of those things fixed and getting the tranny off the body did the trick. It really is unbelievable how noisy these tranny's can be if they're not isolated properly. Goes away when the clutch is pressed in is what made me think of this story. Same thing. I swore it was the TO bearing... nope. In a 914, the tranny is fairly isolated already though so... possibly an issue with your TO bearing or gearstack in general? Is there an RPM associated with it or, as you say, it comes and goes? |
jim_hoyland |
Apr 26 2014, 05:48 PM
Had a similar issue in my 911 when they installed the 915. Went through two clutches and TO bearings. Finally looked at the install and they crammed the tranny against the body, shoved the rubber boot up the tunnel and basically left everything kinda 1/2 assed and undone. I believe the mount was even on upside down. Getting all of those things fixed and getting the tranny off the body did the trick. It really is unbelievable how noisy these tranny's can be if they're not isolated properly. Goes away when the clutch is pressed in is what made me think of this story. Same thing. I swore it was the TO bearing... nope. In a 914, the tranny is fairly isolated already though so... possibly an issue with your TO bearing or gearstack in general? Is there an RPM associated with it or, as you say, it comes and goes? Gear stack was just inspected by Dr Evil; the sound began right after the FW, PP, TO bearing were replaced. I'll have to drive it tomorrow and take note of the RPM situation. Usually most noticed in 4th and 5th |
bulitt |
Apr 27 2014, 06:17 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Possibly the TO bearing is riding against the clutch fingers. You may have to adjust the linkage.
Eric_Shea |
Apr 27 2014, 12:08 PM
QUOTE Gear stack was just inspected by Dr Evil Oh... (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/drunk.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:38 PM |
