Car has been running fine. Recently, there is a sound coming from the right side; sounds similar to a brake pad rubbing against a rotor. Appears at cruzing speeds and goes away when the clutch is pressed in; it comes and goes.
Here's what already been done recently: new flywheel, PP, clutch, TO bearing and pilot bearing. Then Dr Evil looked at the tranny and replaced the pinion gears and 2nd gear dog teeth.
The sound is not loud, barely notice it, but it's annoying. Anyone heard this sound ?; sounds just like the brake pad slightly rubbing on the rotor when adjusting.
