Sound identifcation help needed, Car runs fine, but.... |
jim_hoyland |
Apr 26 2014, 03:31 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Car has been running fine. Recently, there is a sound coming from the right side; sounds similar to a brake pad rubbing against a rotor. Appears at cruzing speeds and goes away when the clutch is pressed in; it comes and goes.
Here's what already been done recently: new flywheel, PP, clutch, TO bearing and pilot bearing. Then Dr Evil looked at the tranny and replaced the pinion gears and 2nd gear dog teeth. The sound is not loud, barely notice it, but it's annoying. Anyone heard this sound ?; sounds just like the brake pad slightly rubbing on the rotor when adjusting. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:07 PM |
