| r_towle |
Apr 27 2014, 01:26 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Does anyone know of a vendor that could take a set of stock 4 bolt Fuchs and either make them wider by welding on a wider outer area, or could cut out the middle to make up a custom 3 piece wheel?
Rich |
| Krieger |
Apr 27 2014, 01:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,847 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I have seen wheels that Harvey Weidman widened. He may do more. He is in Oroville CA He does A+ work
| bulitt |
Apr 27 2014, 01:40 PM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Sounds like a Dave Darling Question...
| r_towle |
Apr 27 2014, 02:24 PM
I have seen wheels that Harvey Weidman widened. He may do more. He is in Oroville CA He does A+ work I have seen a set that was welded and widened as he does it. He widens the inside using two full sets of wheels. The heat ended up creating stress cracks at the laugh nut holes....took a while, but it happened. I want the deep dish appearance while leaving the back spacing the same. For a flared car. |
| Woody |
Apr 27 2014, 03:10 PM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Rebel racing does it with 5 lug Fuchs. Bring money. It may be time to start looking at a 5 lug conversion.
| sixnotfour |
Apr 27 2014, 03:18 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
I can and have done quite a few fuchs centered 17's
Attached thumbnail(s) |
| sixnotfour |
Apr 27 2014, 03:25 PM
Attached thumbnail(s) Attached image(s)
| sixnotfour |
Apr 27 2014, 03:29 PM
| r_towle |
Apr 27 2014, 03:34 PM
Sixnotfour,
How does the center of the 4 lug faux bbs wheel get held in place and not spin? Can you make a set of four lug Fuchs? |
| sixnotfour |
Apr 27 2014, 06:20 PM
Yes, They are interference fit and tig welded on the back side.. like the mahle 4 lugs , also the rim blanks are DOT approved. and polished.
| Mike Bellis |
Apr 27 2014, 07:24 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
This place is the cheapest I found. I plan to use them to widen a pair of 8x16 phone dials to 9x16. They can also make them 17's.. (IMG:style_emoticons/default/idea.gif)
http://www.team3wheels.com/wheel_repair.html There is another more famous and expensive place in Los Angeles That does this but the above place is 10 miles from my house. |
| r_towle |
Apr 27 2014, 08:04 PM
| sixnotfour |
Apr 27 2014, 09:02 PM
what widths do you want ?? Yes I do them on a limited basis..
| rick 918-S |
Apr 27 2014, 09:21 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I got your PM Jeff. Call me about the Enkei 92's I have a set of 4 here.
| r_towle |
Apr 27 2014, 09:35 PM
| Woody |
Apr 27 2014, 09:45 PM
What size? Tires that will fit a 15x9 are becomes scarce unless you are going with race rubber.
| peteyd |
Apr 28 2014, 08:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
| r_towle |
Apr 28 2014, 08:19 AM
What size? Tires that will fit a 15x9 are becomes scarce unless you are going with race rubber. yup, The more I thought about it, the more I realized I would like all 8 inch wheels. Then I can move the rubber around. They would be for autox tires mostly... I have other wheels for street. Just seeing if its doable with 4 lug and save the time of going to 5 lug... Rich |
| Chris H. |
Apr 28 2014, 08:52 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Reminds me of those 8" Pedrinis that floated around for a while...hmeeder's originally.
![]() The Fuchs would be an awesome look Rich. 8" 4 lug! You should be able to get the offset you want. sixnotfour...impressive work man! |
| Chris H. |
Apr 28 2014, 08:55 AM
Nother pic...
Lo-Fi Version | Time is now: 2nd April 2026 - 02:54 PM |
