FS: Boxster Big Brake Setup, Front and Rear |
Qarl |
Apr 27 2014, 08:45 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Boxster Monobloc Big Brake Setup (front and rear).
I purchased this a number of years ago from Rich Johnson. This setup has been mounted on my suspension, but never used (ie., no fluid has been run threw them). I am going to revert back to 911s alloy front calipers and GT-rears. Setup Includes... Front Two NEW Boxster monobloc (Brembo) front calipers. Requires front struts with 3.5" caliper mount spacing Two NEW 24mm Zimmerman Sport (drilled) vented rotors Two billet front caliper mounting adapters Front Brake pads (Mintex), brake pad mounting hardware Mounting bolts Rear Two NEW Boxster monobloc (Brembo) rear calipers Two NEW 20mm Zimmerman Sport (drilled) vented rotors Two billet rear caliper mounting adapters to mount directly to 914 rear trailing arm Rear Brake pads (Mintex), brake pad mounting hardware. Rear pads have been trimed (chamfered) for proper clearance of the rear trailing arms. Mounting bolts This setup requires a 23mm master cylinder (Not included) to provide enough fluid and pedal feel for the four pistons per caliper. Condition. Everything is in VG+ to excellent condition. I've moved the suspension between 2 different houses, so there a couple of tiny nicks on two of the calipers. The rotors are in great condition. 2 rotors have some spots of discoloration on the backside (these were actually like this when I received them a long time ago). Everything has been wiped down and very clean. The rotors have the protective oil still on them (you should always wipe your rotors down with acetone before mounting your calipers and pads). I would rate the overall condition a 9.5 out of 10. This a ready-to-bolt on solution for massive braking power. Great for high-horsepower conversions. Note, you will lose your stock e-brake in the rear, unless you modify your trailing arms for the 911 e-brake setup (search the forums). I'm not sure, but I believe this will fit under a 15" wheel. Buyers should verify. Price Rich currently sells this setup for $2650 plus shipping. (S/H can be expensive as this whole setup is heavy due to the massive rotors). I will let this go for Shipping is only in continental US. I will not ship to AK, HI, PR, or overseas. I can do Paypal (but you will need to pay the fees or add 3%). Cashier's check or cash also accepted. Located in Orlando, FL (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1398653144.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1398655590.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1398653146.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1398653148.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1398653150.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-271-1398653151.5.jpg) Pictures mounted (struts and trailing arms, not included) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.my914-6.com-271-1398653153.6.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.my914-6.com-271-1398653154.7.JPG) |
Qarl |
May 9 2014, 05:55 PM
Price lowered to $1900
horizontally-opposed |
May 9 2014, 11:16 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Great deal on a great setup!
If I hadn't done the alloy PMB thing, I'd be looking at this pretty seriously. While I don't have the tires to take full advantage of these, I've never met a big brake upgrade I didn't like... GLWS! |
Qarl |
May 29 2014, 08:45 AM
sale pending
Lo-Fi Version | Time is now: 10th June 2024 - 05:09 AM |
