Bulldog9 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region ![]() |
Sorry if this is a re-post, but just came across this. Interesting possibilities, wonder if it will come to the U.S.
http://www.autonews.com/article/20140321/O...ter-report-says |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
About time.
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
I like the drop top. :-) up to 395hp?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,487 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Sounds like an alternative to a Subi conversion for a 914, complete with transmission, and you can still participate at Parade.
(IMG:style_emoticons/default/idea.gif) |
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
I know the Boxster is essentially the modern 914, but I just want them to produce the 914 again. (IMG:style_emoticons/default/confused24.gif)
A modernized looking 914 (targa top...even a an old fashioned manual one as we have, two seats, two trunks, etc...) is the perfect platform for an e-vehicle (or hybrid). Maybe Porsche will realize that the styling of the 914 is that good!! Wake me up now...I've been dreaming for decades. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I will venture a guess:
2.5L Direct & port injection. 4 valve, Variable valve timing, intake & exhaust And I dont see breaking the 250 HP mark without a .....Turbo Pretty much a Toybaru FA20 on steroids. The BRZ/FR-Ss are making north of 350HP with only a bolt-on turbo kit and a tune. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,209 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I know the Boxster is essentially the modern 914, but I just want them to produce the 914 again. If they made one without the hybrid stuff on it, it would still weigh 3500 lbs. With the hybrid drivetrain? I'd bet over 2 tons. (IMG:style_emoticons/default/sad.gif) They won't make a 914 again. There isn't enough profit in it. If they can build one that makes enough $$, it will lose just about all of the 914 character. --DD |
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,536 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Sounds like it will be shorter but just as wide as the current Boxter motors.
I bet it still won't fit in a 914 engine bay. (IMG:style_emoticons/default/hissyfit.gif) |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Sounds like an alternative to a Subi conversion for a 914, complete with transmission, and you can still participate at Parade. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/agree.gif) okay if they bring them over I will (IMG:style_emoticons/default/av-943.gif) if they are a rebadged Subaru engine. Stranger things have happened. |
ClayPerrine |
Sounds like an alternative to a Subi conversion for a 914, complete with transmission, and you can still participate at Parade. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/agree.gif) okay if they bring them over I will (IMG:style_emoticons/default/av-943.gif) if they are a rebadged Subaru engine. Stranger things have happened. Did you realize that the first Subaru flat 4 was a Type 1 VW engine converted to water cooling? They later converted it to overhead cams, but the crank, rods and pistons would interchange with the VW stuff. The 2.7L Six in the Subaru SVX was a water cooled 911 2.7 engine. They were so close that you could use the subi main and rod bearings in a 911 engine. The crank wouldn't interchange because Subaru redesigned the nose to work with the timing belt. So a rebadged Subaru motor would be kind of appropriate. |
wobbletop |
Member ![]() ![]() Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada ![]() |
Did you realize that the first Subaru flat 4 was a Type 1 VW engine converted to water cooling? They later converted it to overhead cams, but the crank, rods and pistons would interchange with the VW stuff. The 2.7L Six in the Subaru SVX was a water cooled 911 2.7 engine. They were so close that you could use the subi main and rod bearings in a 911 engine. The crank wouldn't interchange because Subaru redesigned the nose to work with the timing belt. So a rebadged Subaru motor would be kind of appropriate. Do you have any links to back up that history? How do you convert an aircooled engine to water cooling? And the SVX was always 3.3L. |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
I'd love some more info on this new engine.
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Funny,
I met a guy driving a Boxter on the ferry to Long Island a few weeks ago and we talked about 356 prices, early 911's, 914's etc. He said ... "I always thought I would like an outlaw 356, but I would never own a 4 cylinder car." Maybe he would change his mind driving a 395 hp flat four...... John |
Jon H. |
Member ![]() ![]() Group: Members Posts: 242 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada ![]() |
Sounds like an alternative to a Subi conversion for a 914, complete with transmission, and you can still participate at Parade. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/agree.gif) okay if they bring them over I will (IMG:style_emoticons/default/av-943.gif) if they are a rebadged Subaru engine. Stranger things have happened. Did you realize that the first Subaru flat 4 was a Type 1 VW engine converted to water cooling? They later converted it to overhead cams, but the crank, rods and pistons would interchange with the VW stuff. The 2.7L Six in the Subaru SVX was a water cooled 911 2.7 engine. They were so close that you could use the subi main and rod bearings in a 911 engine. The crank wouldn't interchange because Subaru redesigned the nose to work with the timing belt. So a rebadged Subaru motor would be kind of appropriate. The SVX's had EG33 (3.3l) motors which were the same as the EJ22 with two more cylinders. EJ22 pistons interchange with the EG33's. |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Well, the 919 engine, (it's a V4) , is a two liter turbo with 500HP. Probably not as wide as the flat four so maybe it will fit a 914. LOL!! I am sure it would be six figures or more for the engine. If Porsche is getting 500HP out of the V4, don't see why they couldn't get 395 from the flat four for the street.
Sure would like to see some pictures of the new flat four. Tom |
Qarl |
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
Its actually a modern 550 Spyder. That was the inspiration, for the prototype Boxster = convertible 914 = Targa Big difference IMHO (IMG:style_emoticons/default/agree.gif) & cayman = 916 |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,063 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Did you realize that the first Subaru flat 4 was a Type 1 VW engine converted to water cooling? They later converted it to overhead cams, but the crank, rods and pistons would interchange with the VW stuff. The 2.7L Six in the Subaru SVX was a water cooled 911 2.7 engine. They were so close that you could use the subi main and rod bearings in a 911 engine. The crank wouldn't interchange because Subaru redesigned the nose to work with the timing belt. So a rebadged Subaru motor would be kind of appropriate. Do you have any links to back up that history? How do you convert an aircooled engine to water cooling? And the SVX was always 3.3L. He means the Subaru XT I think. This beauty right here: ![]() Came with a 2.7L 6 as an option. Never heard the parts were interchangeable, but Subaru engines are certainly an excellent copy of VW and Porsche flat 4 and 6 engines. If you look at a Type 4 engine and a Subie 4 they are remarkably similar. Subaru started making theirs right about the time VW moved towards water-cooled inline 4's. The Vanagon used an engine that was converted from air cooled to water cooled IIRC. |
Qarl |
Maybe some more clues???
It's not a boxer-four, but they are stuffing a VW motor in the Macan. http://www.topgear.com/uk/car-news/porsche...ampaign=ongoing QUOTE We said it would happen, and it's happened even sooner than we expected: Porsche has dropped a four-cylinder engine into its Macan SUV. Specifically, it's a 2.0-litre four-cylinder turbo, closely related to the engine found in the Golf GTI ‘Performance Pack' and sending 233bhp and 258lb ft of torque to the wheels through Porsche's seven-speed ‘PDK' gearbox. |
dlkawashima |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 11:31 AM |
