"Roaring noise", What makes a loud noise at 30 mph plus? |
brooks944 |
May 11 2014, 02:21 PM
Member Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Hi, my new 914 has a loud noise from the right side when going over about 30. Seems to quiet on a right hand turn. Any ideas on what the problem might be? The PO said it might be an exhaust leak, but that's not it.
Thanks, Rick |
ThePaintedMan |
May 11 2014, 02:38 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Wheel bearing.
Michael N |
May 11 2014, 03:18 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Wheel bearing. (IMG:style_emoticons/default/agree.gif) I had the same issue. Growled when turning one direction. New rear bearings solved the issue. |
r_towle |
May 11 2014, 03:55 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Or CV joint...
ClayPerrine |
May 11 2014, 05:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,502 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hi, my new 914 has a loud noise from the right side when going over about 30. Seems to quiet on a right hand turn. Any ideas on what the problem might be? The PO said it might be an exhaust leak, but that's not it. Thanks, Rick RH rear wheel bearing. Replace both as the other one is now suspect. |
JawjaPorsche |
May 11 2014, 05:10 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Agreed! Rear wheel bearing. Mine made the same noise after 30.
Porsche930dude |
May 11 2014, 05:45 PM
Member Group: Members Posts: 399 Joined: 25-November 11 From: Vestal NY Member No.: 13,819 Region Association: None |
before you install it always pull the rubber seal and pack it with greese because they barely put a tiny smear in the sealed bearings these days so they only last 3 or 4 years if you dont put more greese in. this goes for all brands of bearings and cars
Larmo63 |
May 11 2014, 06:26 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
On this same subject, where is the recommended for these parts?
Fronts and rears + seals? |
bdstone914 |
May 11 2014, 06:51 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
On this same subject, where is the recommended for these parts? Fronts and rears + seals? Pelican has them get the rears that are the FAG bearings made in Slovakia which are half the price of the German made bearings. Fronts are easy. Rears take the right tools to remove the hubs and bearings. If the fronts are not making noise I would leave them alone. Rears are at least a half day job to pull the axles, hubs and bearings. I have the tools to do it without damaging the hubs. Bruce |
Lo-Fi Version | Time is now: 1st June 2024 - 12:17 PM |
