WTB - 914-4 front A-arms |
914forme |
May 11 2014, 04:29 PM
I need a set of 914-4 front A-arms, these need to be -4 so the splines are correct for my 21mm torsion bars. Straight good condition, I will also need the rear T-bar caps.
I have a set of 911s that have ~19mm torsion bars if you would want to trade up. |
bdstone914 |
May 11 2014, 06:01 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I need a set of 914-4 front A-arms, these need to be -4 so the splines are correct for my 21mm torsion bars. Straight good condition, I will also need the rear T-bar caps. I have a set of 911s that have ~19mm torsion bars if you would want to trade up. I have a pair of -4 A arms I will trade for 911 A arms. Do you have the torsion bar clamps for them ? Do you need the sway bar tabs on them ? Bruce |
bdstone914 |
May 11 2014, 06:29 PM
I need a set of 914-4 front A-arms, these need to be -4 so the splines are correct for my 21mm torsion bars. Straight good condition, I will also need the rear T-bar caps. I have a set of 911s that have ~19mm torsion bars if you would want to trade up. I have a pair of -4 A arms I will trade for 911 A arms. Do you have the torsion bar caps for them ? Do you need the sway bar tabs on them ? Do the 911 A have the U tab for the through body sway bar or the loop bracket for the under body sway bar ? Bruce |
danimal16 |
May 12 2014, 10:26 AM
Newbie Group: Members Posts: 11 Joined: 2-March 12 From: Murrieta California Member No.: 14,202 Region Association: Southern California |
You have a PM.
V/R Dan B |
Lo-Fi Version | Time is now: 10th June 2024 - 12:01 AM |
