? Better alternator, has anyone modified a gm or sim? |
jwalters |
Jan 15 2005, 10:23 AM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Hi guys, has anyone here modified a better alternator to take the place of the stock meager one? I would like to go with an internal regulated one wire model--or any other model which puts out more amperage.
Thanks in advance- (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Allan |
Jan 15 2005, 10:25 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
jwalters |
Jan 15 2005, 10:33 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Thanks there Rage---I did a search but that particular thread did not appear for me--sometimes the search goes a little crazy and I get hundreds of stuff--seriously not enough time to go thru them............ (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
lapuwali |
Jan 15 2005, 10:52 AM
Look in the vendor section for davep. He has the stock unit rewound to put out more current.
Dave_Darling |
Jan 15 2005, 12:05 PM
I believe that Griznant from the shoptalkforums BBS modified the drive shaft on a GM "one-wire" alternator to accept the stock 914 pulley. (Turned it down on a lathe.) He then bolted it right up to the 914 motor in his 912 (stock cooling, not an "upright" conversion). No provision for getting cooling air into the alternator housing like the stock one has, so durability may be an issue.
...Or may not, time will tell! --DD |
Mark Henry |
Jan 15 2005, 01:49 PM
Davep bumps the stocker up to 75amp which should be plenty. Stock is 55amps.
He's a real good guy. |
94teener |
Jan 15 2005, 08:32 PM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
Aaron Cox |
Jan 15 2005, 08:41 PM
gm alternators have a fan behind the pully that blows air into them.... problen solved |
Lo-Fi Version | Time is now: 1st June 2024 - 08:46 PM |
