| jmalone |
May 14 2014, 02:19 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California
I am wondering whether to add a tuna can to my stock 2.0. Is it a prudent upgrade? Also I don't see a lot of deep sumps used by members, is there some reason that the Tuna Can solution is preferred?
(As a retired commercial tuna fisherman, I prefer my tuna in water anyway, not in 10/40) |
| Cap'n Krusty |
May 14 2014, 03:08 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I am wondering whether to add a tuna can to my stock 2.0. Is it a prudent upgrade? Also I don't see a lot of deep sumps used by members, is there some reason that the Tuna Can solution is preferred? (As a retired commercial tuna fisherman, I prefer my tuna in water anyway, not in 10/40) I may be wrong, but I'm not aware of a "deep sump" other than the Tuna can. There's really no way to fasten one to the bottom of the engine. Considering the existing ground clearance with the suspension loaded, extending the sump, even with a tuna can, is a bit unnerving. The Cap'n |
| Elliot Cannon |
May 14 2014, 03:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Unless you're racing or auto crossing, I wouldn't bother.
| Blm94 |
May 14 2014, 06:08 PM
Newbie ![]() Group: Members Posts: 3 Joined: 6-October 13 From: Iowa Member No.: 16,479 Region Association: None |
| Elliot Cannon |
May 14 2014, 06:48 PM
Looks nice under there. Skid plate =good idea. (IMG:style_emoticons/default/biggrin.gif)
| URY914 |
May 14 2014, 07:15 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,679 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I have a Type-IV deep sump but run a tuna can on my car.
Tuna cans are or were made of both aluminum and steel. I have both but run the aluminum one. |
| URY914 |
May 14 2014, 07:17 PM
[/quote] I may be wrong, but I'm not aware of a "deep sump" other than the Tuna can. There's really no way to fasten one to the bottom of the engine. Considering the existing ground clearance with the suspension loaded, extending the sump, even with a tuna can, is a bit unnerving. The Cap'n [/quote] You are wrong on this one. I have one. It bolts on. The Cap'n wrong? Wow, who knew? (IMG:style_emoticons/default/confused24.gif) |
| vw505 |
May 15 2014, 08:39 AM
Member ![]() ![]() Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
| vw505 |
May 15 2014, 08:41 AM
I have a deep sump on mine, I end up with 5QT's of oil in the system.
| GaroldShaffer |
May 15 2014, 08:54 AM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,643 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
I have a tuna can on mine. My car is used for both street & autocrossing.
| Randal |
May 15 2014, 08:57 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
| vw505 |
May 15 2014, 09:04 AM
Turbo return line.....
| 1stworks |
May 15 2014, 09:45 AM
Member ![]() ![]() Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
| brant |
May 15 2014, 10:52 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,159 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
And a tuna can can be used for something more important! boy the webbing on the case that the stock strainer/tuna can uses for attatchment doesn't seem strong enough for this idea... a lot of leverage is added to your can with that small line vibration isn't going to be a friend of that engineering brant |
| brant |
May 15 2014, 11:11 AM
I am wondering whether to add a tuna can to my stock 2.0. Is it a prudent upgrade? Also I don't see a lot of deep sumps used by members, is there some reason that the Tuna Can solution is preferred? (As a retired commercial tuna fisherman, I prefer my tuna in water anyway, not in 10/40) on my old race car, we added a 2nd oil warning light with a 15psi warning threshold, instead of stock 3psi light in the dash its really pretty amazing to see how frequently the type 4 motor is below 15pounds of pressure in the corners.... and remember this was a race car with a high output, high pressure oiling system that was always over 100psi cold, and always running 30-50psi on the oil pressure gauge when hot... not a low rpm engine, not a tired engine with bad pressure. so having said all of that I run tuna can's on my street cars I think that the stock motor design does not have adequate pick up, for modern tires and modern G forces.... perfectly adequate for micheline xzx 165 series tires! |
| Cap'n Krusty |
May 15 2014, 11:47 AM
I would be interested in seeing exactly how the deep sump unit is secured to the case. On T1s and 356/912 engines, there are 6 and 10 bolts, respectively, to mount it to the case. There is no such provision on the T4. As for that "skid plate", I see no structural integrity whatsoever, it appears to be nothing more than eye candy; my eyes are old, but it looks like one glancing blow and it's gone, along with whatever it's bolted to.
The Cap'n |
| Bills914-4 |
May 15 2014, 03:31 PM
Member ![]() ![]() Group: Members Posts: 313 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Here you go Cap'n , this is a new one for my future twin plug (IMG:style_emoticons/default/smile.gif) , I've modified mine
by milling an angle on the riser that sits in the step of the case so that it mounts more flush to bottom of the motor (IMG:style_emoticons/default/smile.gif) , Bill D. here is pic of my old one mounted here's pic's of the new one |
| Mark Henry |
May 15 2014, 03:58 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I've always thought the deep sump fit, the way it hangs down, sucks.
I also don't like that turbo oil return line, hot foamy oil going straight to the pick-up, the engine won't live long. I would have run it to the taco plate or machined the bus oil fill or pump boss. |
| Cap'n Krusty |
May 15 2014, 04:33 PM
Thanks for the picture. Is it difficult to fit that bracket between the case and the oil pickup. I don't remember how much clearance there is, but I think it's not much. All things considered, I don't think I'd use one of those.
The Cap'n |
| Randal |
May 16 2014, 10:31 AM
And a tuna can can be used for something more important! boy the webbing on the case that the stock strainer/tuna can uses for attatchment doesn't seem strong enough for this idea... a lot of leverage is added to your can with that small line vibration isn't going to be a friend of that engineering brant There is a lot more engineering you can't see. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 14th March 2026 - 04:12 PM |
