buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
I assume it is on the passenger side cylinder head toward the back of the car but where is it? Do I have to take off the tin to get to it?
Thanks, Buck By the way it was way easier to hook up a 3.2 f.i. system then putting a d-jet back on a 1.7. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,023 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I assume it is on the passenger side cylinder head toward the back of the car but where is it? Do I have to take off the tin to get to it? Thanks, Buck By the way it was way easier to hook up a 3.2 f.i. system then putting a d-jet back on a 1.7. It is on the passenger side. It can be removed without removing the tin if you can improvise a tool. Some people have cut a slit in a deep well socket to clear the wire. You can notch the end of the socket that takes the ratchet. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,956 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Located on passenger side towards the back of the engine. There's a hole in the tin to reach it. Takes 2 minutes to remove or install. Buy a $5 deep well socket. Stuff the wire into the socket to remove and reinstall. No cutting, grinding or tin removal needed.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Look around for holes in the engine tin near the #3 spark plug. There should be one hole with a single wire coming up out of it; that's the Temp Sensor II wire and the sensor is at the end of it.
--DD |
Lo-Fi Version | Time is now: 4th July 2025 - 09:22 PM |
