Various Engine Wiring Q's, wheres that thing go? |
jandro62 |
Jan 16 2005, 09:42 AM
Member Group: Members Posts: 104 Joined: 4-June 04 From: Texas Member No.: 2,156 |
So how many wires from the harness do I have going to the positive side of the coil and to the negative side of the coil?
Mueller |
Jan 16 2005, 09:48 AM
normally 2 from the wiring harness
tach wire = - side switched positive = + side 1 wire (if points) will go the the - side if electronic ignition, it depends on the brand |
ejm |
Jan 16 2005, 10:33 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
and if you're running L-jet there is a white wire that goes to the (-) side
Lo-Fi Version | Time is now: 9th June 2024 - 10:15 AM |
