Clutch not working? |
WifesCar |
May 27 2014, 10:03 AM
Newbie Group: Members Posts: 2 Joined: 27-May 14 From: Fernie, BC Member No.: 17,413 Region Association: Canada |
I was just taking our 1975 1.8L out of Winter storage and couldn't get it into any gears! It worked fine last fall. With the vehicle off, it runs through the gears. When it's running, I can't shift without it grinding. It reacts like there is no clutch at all.
The cable on the transmission side appears fine, although I was surprised by how little it moves when somebody engages the clutch. Is it possible for the cable to stretch over the winter? Or the threaded bolt on the end to back off! Doesn't make sense?? |
Valy |
May 27 2014, 10:15 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I was just taking our 1975 1.8L out of Winter storage and couldn't get it into any gears! It worked fine last fall. With the vehicle off, it runs through the gears. When it's running, I can't shift without it grinding. It reacts like there is no clutch at all. The cable on the transmission side appears fine, although I was surprised by how little it moves when somebody engages the clutch. Is it possible for the cable to stretch over the winter? Or the threaded bolt on the end to back off! Doesn't make sense?? Check the cable tube in the tunnel. Looks like it snapped. I see some welding in your future. |
ripper911 |
May 27 2014, 10:47 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
You could tighten the nuts on the transmission end a few turns to see if it helps.
toolguy |
May 27 2014, 10:50 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Check the cable tube in the tunnel. Looks like it snapped. I see some welding in your future. If the cable snapped, the pedal would be on the floor. . If the clutch arm does not move much when someone presses the pedal, check the bosen tube welds. .they may have snapped and the tube is flexing in the tunnel. . The clutch arm should move about 3/4 -1 inch when pedal depressed |
zambezi |
May 27 2014, 11:09 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
This is a classic case of the clutch disc rusted to the flywheel. find an area with a clear run where you will not hit anything and start the car in gear with your foot down on the clutch. The car will drive forward because of the rusted disc. once the car starts forward and has enough momentum, stab at the brakes this usually shocks the clutch disc free. I have had to do that at least 3 times on other cars, my 914 included. It may take more than one attempt but almost always works without having to pull the trans and free the disc the hard way. Once free all should be good.
WifesCar |
May 27 2014, 12:20 PM
This is a classic case of the clutch disc rusted to the flywheel. find an area with a clear run where you will not hit anything and start the car in gear with your foot down on the clutch. The car will drive forward because of the rusted disc. once the car starts forward and has enough momentum, stab at the brakes this usually shocks the clutch disc free. I have had to do that at least 3 times on other cars, my 914 included. It may take more than one attempt but almost always works without having to pull the trans and free the disc the hard way. Once free all should be good. This seems to be the most logical. Free play in the pedal seems right, pressure seems right, everything seems right except it's not disengaging the clutch disc. I was fearing the release fork snapped, but I suppose there would be no clutch tension then.... Also makes sense because of the prolonged time it has been sitting in a cold climate. I'll visually go over everything starting under the pedal, push it outta the garage and give it a run! THanks Zambezi and everyone! |
Lo-Fi Version | Time is now: 8th June 2024 - 07:01 PM |
